Author Topic: Are there any plans for the Arcade1ups?  (Read 6820 times)
nadcraker
  • Last login:December 01, 2025, 01:01:55 pm
« on: December 18, 2019, 03:55:10 pm »
Has anyone made any plans available for the Arcade 1ups? I like the cabinets but want to use higher quality components.
negative1
  • Last login:December 18, 2025, 09:12:44 pm
Re: Are there any plans for the Arcade1ups?
« Reply #1 on: December 19, 2019, 12:47:59 pm »
Probably.
Best place to ask/check:
https://www.reddit.com/r/Arcade1Up/new/
later
-1
  • Last login:Today at 02:02:09 am
« Reply #2 on: December 19, 2019, 02:04:03 pm »
Buy one for cheap and use the parts as router templates.
JDFan
« Reply #3 on: December 19, 2019, 02:15:09 pm »
Arcadegraphix.com has template downloads for the artwork they print for them - those should provide the info needed.
  • Last login:December 16, 2025, 04:07:15 pm
« Reply #4 on: December 19, 2019, 07:32:41 pm »
Yeah, that's the suggestion I was going to make.
I'm doing a Arcade1up to Gorf conversion now and I remember disliking 1/2" material. Nothings changed, I still don't like 1/2" MDF. I understand why they used it, and I think the cabinet looks fine but putting screws into it is a pain.
JDFan
« Reply #5 on: December 20, 2019, 03:14:11 pm »
YEah - At least A1U is using the metal inserts ( cross dowels ) in the side panels etc. to provide that extra stability and durability for those connections. http://www.theinsertcompany.com/cross_dowels.php
« Last Edit: December 20, 2019, 03:23:46 pm by JDFan »
