Author Topic: [SOLVED] Not able to boot with two screens connected after using Atom-15  (Read 2387 times)
Max_FS
  • Last login:June 21, 2025, 03:48:01 am
Dear all,
I just flashed my bios with Atom-15 and at first sight it all worked well.
When booting the PC with only the CRT connected, there is no problem. However, when I have a second screen connected (LCD-Screen used as as dynamic marquee) the CRT looses the signal after the first seconds of booting. Then I have to unplug the second screen and restart windows. After that I plug the second screen in and it works.
May anyone help with this?
My setup:
ASUS Z87-A Mainboard
Intel Pentium G3258 CPU
Sapphire Radeon HD 6450 GPU with CRT EMU-Driver, flashed with Atom-15
Windows 7
Sony Trinitron CRT as first screen
Stretched LCD as second screen
GroovyMame (version 0.214)
AttractMode (version 2.6.0)
Best regards
Max
« Last Edit: April 12, 2020, 11:11:44 am by Max_FS »
Max_FS
Re: Not able to boot with two scrrens connected after using Atom-15
« Reply #1 on: April 04, 2020, 04:08:18 pm »
I could not solve the problem. If anybody else has the same issue, my solution now is to use a switch-on delay so the second screen is powered 8 seconds later than the first screen.
  • Online Online
  • Last login:Today at 04:37:25 am
« Reply #2 on: April 04, 2020, 04:32:44 pm »
Hi Max_FS,
Sorry this went unanswered. There's no solution for this I'm afraid, except what you did. ATOM-15 is not actually meant for multi-monitor, specially if you use an LCD too. The video card will detect the LCD monitor and decide it's the main display and will automatically send the video to it.
Max_FS
« Reply #3 on: April 04, 2020, 05:11:16 pm »
Hi Calamity,
no problem, as this could be solved in the end.
And I already have another question with regard to my multimonitor-setup (just preparing a new topic at the moment) :-D
