Author Topic: Compiling MAME: qt5 linking error  (Read 2440 times)
keilmillerjr
  • Web Developer.
« on: November 20, 2019, 04:35:56 pm »
Perhaps its lack of sleep, but I am having an issue compiling mame on a fresh virtual install. I did install qt5. Same process I have used to compile a dozen different versions I patched. Any ideas? Was excited to get some testing done.
Substring
  • Last login:November 23, 2025, 01:16:00 pm
  • Forking GroovyArcade
    • forum.arcadecontrols.com/index.php/topic,160023.0.html
    • GroovyArcade active fork
Re: Compiling MAME: qt5 linking error
« Reply #1 on: November 20, 2019, 05:03:37 pm »
the missing .so are in /usr/lib
Have you installed dependencies as explained in https://docs.mamedev.org/initialsetup/compilingmame.html#arch-linux ?
The arch linux package goes even further : https://www.archlinux.org/packages/community/x86_64/mame/ (the make dependencies may not be installed by default)
Have you installed arch's base-devel package ? maybe you're missing pkg-config ?
keilmillerjr
  • Web Developer.
« Reply #2 on: November 20, 2019, 05:14:14 pm »
Yes, I did install required dependancies. I even described the whole process I have used multiple times on the arcademvs wiki. Similar process I use for arch and mac. I tried reinstalling qt5 package. Perhaps I will try reinstalling the rest again in the morning. Work, 1hr sleep, back to work 16hrs.
Doozer
  • Last login:June 12, 2023, 09:19:49 am
  • Z80 ERROR
« Reply #3 on: November 21, 2019, 08:08:47 am »
Unless you are using the debug interface, the QT5 part can be disabled by using USE_QTDEBUG=0 parameter. No need to install QT5 lbs in that case.
