Author Topic: Bypass motherboard verification  (Read 3920 times)
theck35
  • Last login:December 22, 2019, 07:38:10 pm
« on: November 18, 2019, 06:29:24 am »
hello
need help for bypass motherboard check on megatouch crown
booting after MAxx loading screec error : (Invalid motherboard detected)
  • Last login:Yesterday at 01:40:05 pm
Re: Bypass motherboard verification
« Reply #1 on: November 18, 2019, 01:00:55 pm »
i guess the 1st question is...did you actually replace the motherboard with some random motherboard you found? ... or did it just randomly pop up and say this one day?
if it's the latter it could be bad drive in which case, Reload software, check security key is properly installed and the riser boards are properly plugged in (remove clean/reinstall).
if it's the former.... for obvious reasons, you can't just plotz a random motherboard into the system and expect it to work. the software is designed to work with a very select few makes/models of boards. (mitsubishi ITOX/telco 586/unicorn) and will not work with anything else.
mahkeymike
  • Last login:January 15, 2026, 03:00:29 pm
« Reply #2 on: November 19, 2019, 10:04:12 pm »
1st post member, asking for hacks. You have more willingness to help then me shawn.
« Reply #3 on: November 20, 2019, 11:21:57 am »
meh, I don't even expect they would respond or even come back. i posted more for prosperity's sake for future garglers looking to ask the same question.
