Author Topic: Ultrastick problem with Win10  (Read 1070 times)
GeoMan
  • Last login:December 16, 2025, 02:09:05 pm
« on: November 12, 2019, 06:05:03 am »
I had a fully working Ultrastick under Win7 able to program it with Ultramap 2.0
I upgraded my Win7 to Win10 (1903) and although the Ultrastick works with the last programmed settings from Win7, Ultramap reports that the driver was installed correctly but it doesn't recognize that it is plugged in, so i can not reprogram it.
The funny thing is that the Ultrastick works in the Ultramap window and shows the correct mapping.
I re-installed Ultramap (as Admin), i run the program As Admin, nothing changed.
Any solutions?
UPDATE: Solved the problem by removing and reattaching the Ultrastick.
« Last Edit: November 12, 2019, 06:13:01 am by GeoMan »
