Author Topic: Outrun 2006 / FXT won't trigger Logitech Profiler  (Read 5226 times)
jacko1
  • Last login:October 17, 2021, 07:25:03 pm
« on: September 19, 2019, 05:28:03 pm »
The Logitech Profiler software I use to adjust degrees for my G29 wheel will not recognize when either Outrun 2006 original EXE or the FXT one are launched.  This problem existed before I installed FXT and continued after.  The Logitech Profiler seems to work fine with many other executables.
I'm totally new to Outrun 2006, just started playing with it yesterday and installed FTX as well.  It's mostly working OK and I can manually force the wheel to a default setting as a workaround, but that's not really a good solution.  If anyone has ideas I'd love to hear them, thanks.
Foxhole
  • Last login:May 09, 2025, 05:02:07 pm
Re: Outrun 2006 / FXT won't trigger Logitech Profiler
« Reply #1 on: November 13, 2019, 01:54:20 am »
Didn't work for me too at first, but after adding both exe's, OR2FXT.exe and OR2006C2C.EXE, to the logitech profile, it worked.
