Author Topic: Star Wars YOKE- Buy should I or Ebay original hunt down do I?  (Read 46353 times)
tommyinajar
  • Last login:November 15, 2023, 12:23:20 pm
  • My other cab is a Cube Quest
« on: September 19, 2019, 01:41:49 pm »
I'm looking for a Star Wars YOKE. Ebay seems to sell for $400+ in varying degrees of 'brokeness'-
Any-1 buy one of these?
https://alan-1.com/product/alan-1-star-wars-flight-yoke/
They also have USB hookup for said stick for $99- with ebay$$ this seems decent? No RAM controls here hopefully.....any other options?
  • Last login:Yesterday at 01:03:13 pm
Re: Star Wars YOKE- Buy should I or Ebay original hunt down do I?
« Reply #1 on: September 19, 2019, 01:56:56 pm »
Oops. didn't see you already linked to the Alan 1 site. Sorry. Those are getting good reviews.
« Last Edit: September 19, 2019, 02:18:36 pm by Mike A »
behrmr
« Reply #2 on: September 19, 2019, 01:59:36 pm »
No, this is not RAM controls so you're good to go.  The yoke looks great and I've seen some reviews of it and they are positive.   The USB adapter works well just make sure you update the firmware to the correct version if you plan on using it with MAME.  There's a "linux" version for RetroPie and a "windows" so choose the correct one (both are flashed from a windows pc).
  • Last login:Today at 05:54:40 am
« Reply #3 on: September 19, 2019, 02:29:29 pm »
Alan is a highly respected long-timer on KLOV and here.   ;D
- Definitely not a RAMSCAM Controls situation.
If his USB encoder is too expensive for your budget, you can use an A-Pac or roll-your-own with an AVR/Arduino.
- Parts list and pinout here for the molex connector/pins to connect to the A-Pac or AVR/Arduino.
- Instead of the older KADESTICK firmware from that thread with a MattairTech MT-DB-U4 AVR, you may want to use the newer KADE miniArcade 2.0 firmware here with an Arduino Pro Micro.
negative1
  • Last login:Yesterday at 10:15:39 am
« Reply #4 on: September 22, 2019, 07:38:44 pm »
You might want to check on this replica also, its a protoype now,
but be coming out later on:
later
-1
Mr. Peabody
  • Last login:November 11, 2025, 07:08:52 pm
« Reply #5 on: September 23, 2019, 12:56:24 pm »
GRS yoke: nice try, but no cigar. His 'spinner' and 'Tron joystick' further example this. Made for the goobs, not us.
jdbailey1206
« Reply #6 on: September 27, 2019, 11:15:17 am »
It really depends on what you want to do Tommy.  If you are only looking for one as a controller and do the following:
  • Use one as a controller
  • Use one as a controller and then put in into a SW cab at a later date or
  • Purchase one and immediately put it into a SW cab
then I would recommend buying both the yoke and adapter.  Or buy the yoke and put your own adapter together as Scott has recommended.  Thought buying both from Alan 1 will be so much better as it was plug and play for me on my XP desktop setup.
Having never used one growing up I cannot compare the game play but if the originals were anything like these reproductions I definitively missed out.  Game play was so much smoother when used in The Star Wars Trilogy ('98) than with a common joystick.  In the end I would highly recommend purchasing one.  Even if you have to save up.  Checking today they are still in stock and have gone down in price by $150.00   :banghead:  Oh well.  I still think its worth the $500 I paid six months ago.
Your only alternative is to buy one of these which having seen and played a Rampage version IRL I don't recommend doing.
tommyinajar
« Reply #7 on: September 27, 2019, 02:10:58 pm »
 Yea- yoke is going on a removable CP along with about 7 other custom "1 game" CP's.
 I'm getting parts together, plan to start when temp drops outside. I'll post when I'm getting somewhere, not 100% sure how to exactly mount the cp's- So far industrial velcro or magnets (electronically controlled???  >:D ) are what I'm thinking. No rotating panels here folks! KISS- Not going down the beyond my current skills rabbit hole -again....
  Basically, I like playing actual original cab games the best, so Mame with 1:1 CP's is about the best you can reasonably do, right?
So far I'm doing Stargate(Defender), Robotron, Front line, Ikari, (Track n field/ Asteroids), (Super Sprint/racing)- And maybe a Spyhunter +/- Roadblaster Frankenstein lastly, not sure about that, what 2 controllers for 3 games- Spyhunter, Road blasters off-road?
But I have to have a SW yoke too, right?
Any others I should consider recommendation wise?
Huh-
 I had no clue THAT was happening, IDK nor can I imagine what the yoke on that is going to be like, after seeing previous 1-ups
controls....
« Last Edit: September 27, 2019, 02:13:07 pm by tommyinajar »
« Reply #8 on: September 27, 2019, 11:24:13 pm »
There are a number of games that will work well with the SW yoke, including positional gun games or racing games that used a 270 degree steering wheel.
- There's a list of yoke games and positional gun games on the wiki "Joysticks" page, 2/3rds of the way down.
Spyhunter has an X-axis pot for steering, 5 buttons, a 2 position shifter, and a potentiometer pedal.
- An LED "Weapons Van" button + your SW yoke and you've got steering and buttons covered.
The Road Blasters controller has stop bumpers to limit rotation like the SW yoke, but instead of an X-axis pot for steering, it used an optical encoder wheel. (see pg 45 of the manual here)
- SW yoke should work fine for this.  Same grips, same X-axis range of motion.
Off-Road uses a 360 degree steering wheel, so you don't want to use the SW yoke with that type of game.
negative1
« Reply #9 on: September 29, 2019, 02:41:10 pm »
Huh-
controls....
This has been mentioned in the arcade 1up forum quite awhile ago.
They worked with the alan-1 manufacturer, and will have a scaled down plastic version.
Also, the one I mentioned earlier will be an upgrade from that.
The reason cost for the alan-1 yoke went down, is because they made a deal with the arcade 1up for
a lot more units.
There is a huge thread on KLOV about the whole story, and details about the hardware.
later
-1
negative1
« Reply #10 on: September 29, 2019, 10:18:04 pm »
here's a good review of the alan-1 yoke:
later
-1
Mr. Peabody
« Reply #11 on: September 30, 2019, 05:33:39 pm »
Pot control games and optical control games do not mix. Using a spinner for the latter is beyond adequate. Easier in some cases due to far less rotation necessary.
Alan-1 yoke: do not think, do not feel, do not breath. Press the 'buy it now' button. Now.
bobbyb13
  • Last login:February 01, 2026, 08:01:04 pm
« Reply #12 on: October 19, 2019, 08:01:53 pm »
Now that the price is what it is (do we have the 1Up guys to thank for that I imagine?!) don't waste any time and just buy one.
Mine just arrived this week and it is an impressively built unit.
I can say it is well worth the original price in fact now that I own one (I just couldn't justify spending the $$ until the recent fortuitous price drop.)
Can't get my upright cabinet built fast enough now.   :laugh2:
I have had great luck with various interface units from Andy at Ultimarc but I think the Alan-1 yoke may best be used with their purpose built board.
I have found from experience building my multi-control cocktail cab that mixing mousey controls in a single interface board can get messy.
Bobby
« Reply #13 on: October 20, 2019, 12:36:54 am »
1. IMNSHO "may best be used" is a potentially misleading assertion regarding their encoder board.
- An Arduino with a decent firmware or an A-Pac will work every bit as well as their board for a fraction of the cost.
- If someone doesn't know how to crimp Molex pins, solder, and/or load firmware on an Arduino, then the Alan-1 board could arguably be the better option for them.
- That said, almost everyone around here either already has those skills or can easily learn them.  YMMV.
2. There are no "mousey controls" involved here.
- The SW yoke uses potentiometers (analog joystick gamepad encoder), not optical circuits. (mouse encoder)
bobbyb13
« Reply #14 on: October 22, 2019, 05:18:36 am »
Consider me rightfully admonished Scott-
Proprietary board from Alan-1 suggestion only meant as a turn-key solution (for a newb like myself!)
I'm embarking on the same journey that tommyinajar is braving for my upright cab and even with a lot of research the input board question has been a head scratcher.
I learned the hard(er) way that the Mini-Pac with both a trackball and spinner connected actually blends the inputs from both (even if you try to isolate them in MAME) and I wasn't sure if interference likewise occurs with pots through the same board for a Star Wars yoke.
I suppose it only applies to optical devices.
Brings up another thought/question I have that I suppose I should be courteous and begin a new thread about.
Aloha,
Bobby
Mr. Peabody
« Reply #15 on: October 22, 2019, 04:29:09 pm »
Ultimarc optical controllers don't combine the inputs. The devices share an axis/es - which is fine in 99.99999% of cases...if not more.
But you're not understanding: optical and analog are separate protocols. There's no cross-over......
bobbyb13
« Reply #16 on: October 23, 2019, 03:51:55 am »
Not surprised that I would be that  0.00001% who found a way to screw it up.
I really do understand that optical and potentiometer devices are different animals, but from a functional standpoint even just the potential sharing of an axis on my control panel certainly led to unintentional input.
i.e. Play Centipede and bump your spinner and wind up with your archer pinned on the side of the screen for a few seconds.
When I asked Andy himself about the interference between the trackball and spinner on my first cab his reply was, and I don't imagine he will mind if I quote:
"If the trackball and spinner are connected via the Mini-PAC they will be combined, but if either has its own USB interface option...  they will be separate."
I thought I was lucking out that I could connect both via one interface board- but it is problematic.  I missed the caveat about this possibility I guess.
Like tommyinajar presently, I am building a cab to utilize an Alan-1 yoke, pedals, shifter, and buttons and my thought was that possibly an interface for analog controls might do the same as my MiniPac was doing for the optical ones I have here presently.
Not a concern for devices that utilize separate usb connections for each it appears (or for pot driven ones either apparently.)
But if it could be an issue I am sure that I will inadvertently find the method.
It may be that the way to address all possibilities is a U-HID board but I won't be sure until I get one and find the infinitesimally obscure means to screw that up too.
I hope the OP fairs better!
« Reply #17 on: October 23, 2019, 12:54:51 pm »
Sounds like you'll want 5 separate analog axes -- 2 for the yoke and 3 for the pedals.
The full-size U-HID can handle up to 8 separate analog axes plus all of the microswitches in the buttons, yoke, and shifter.
If you want a less expensive alternative, the miniArcade 2.0 firmware can handle 5 separate analog axes and a bunch of buttons.
bobbyb13
« Reply #18 on: October 23, 2019, 02:46:03 pm »
Invaluable info Scott- thank you for the replies.
I appreciate that the reward for respectful ignorance here can be getting to learn something new.
Time for more research and thank you for the direction!
Aloha,
Bobby
Zebra
« Reply #19 on: October 23, 2019, 03:36:16 pm »
You'd be able to get that many analog axis by hacking a regular game pad (the kind with two analog thumb sticks and triggers). They use two pots per stick (one for each axis) and a pot for each of the analog buttons which could easily be wired to pedal pots. Most of those pads have 6 or 8 axis.
The part I am never sure about with star wars yokes is if it's not better to buy one of the many other USB flight yokes on ebay that are plug in and play. Sure, they don't have the Atari sticker but it's a fact of life that playing arcade games at home usually means you can't use the exact original controller for each game. I'm usually OK as long as I am using the right type of controller.
I know that some of those reproduction Star Wars Yokes are well made but it might also be worth checking out what other USB yokes you could get for $350+. Some of them look sweet.
  • Last login:February 01, 2026, 01:32:52 pm
« Reply #20 on: October 24, 2019, 12:22:59 am »
Eh I built one with some lego technic gears about couple of old joystick grips and some lamp rod.... If you want it exact then yes you'll have to pay up, but if you just want the general feel then it's not a terribly complicated piece of hardware to clone.  I'm actually surprised we don't have a 3d printable star wars yoke yet.  The handles would be tricky to model, but the gears wouldn't.
Zebra
« Reply #21 on: October 24, 2019, 01:55:02 pm »
My (albeit limited) experience with gears is that they require an accurate production machine and need to be made of a hard material to be decent. I'm not sure what sort of quality of gear you'd get from a typical cheap home 3d printer.
I know that there are people who definitely do make gears on home 3d printers but I'd want something a lot stronger than your typical abs plastic for an arcade flight yoke. You can usually snap thin abs parts (like gears) easily with your fingers. I think you'd strip abs gears very quickly. I wouldn't trust softer metals like aluminum either, unless it was a tempered 7075.
The nylon composite used in arcade gears may not look it but it's an extremely durable material with high impact strength. For a diy variant, I'd probably want to cnc machine the gear from brass or even steel if the machine is up to it. Then get it hardened.
Ready made metal gears are usually not too expensive at the hobby level though. It may be one of those parts where most people would find it cheaper and easier to buy instead of make.
Mr. Peabody
« Reply #22 on: October 24, 2019, 04:10:13 pm »
.....look at the specs of the yoke. They gave it metal gears because of plastic fatigue.
The mechanical design and function of the yoke must be copied. You want a cheap whore, feel free.
bobbyb13
« Reply #23 on: October 25, 2019, 01:06:53 am »
I think those original gears were made of Delrin.  In an arcade machine I think failure would be due almost exclusively to age alone if they were made of that stuff.
It is considerably tougher than anything I imagine people typically use for 3d printing though.
I have a friend with a 3d printer I will have to ask about materials.
Would be excellent to see about being able to make yoke replacement/build parts that way.
For a plastic, Delrin is slicker than snot though so I bet it is tricky to work with (not sure I would want to be huffing formaldehyde gas if you got it too hot either.)
« Reply #24 on: October 25, 2019, 11:31:46 am »
Acetal (a.k.a. Delrin or POM) filament is available here.
Looks like you'll need a non-standard print bed surface, heated bed, heated chamber, an all metal hotend, and good ventilation.
Zebra
« Reply #25 on: October 25, 2019, 12:53:03 pm »
There is a newer generation of 3d printers that allow the use of stronger spools like those containing carbon fiber or higher melt point polymers. These don't offer the same benefits as woven heat cure carbon fiber or industrial polymer casting processes but they will certainly increase strength and stiffness over ABS but probably not hardness. It will never be as good as steel gears but it could be fine for a gaming peripheral with no force feedback.
Regardless of materials, you still can't make decent gears with a low quality low res 3d printer. Quality gears require a level of precision and accuracy or they will never feel right. For this reason, I'd buy a stereolithography 3d printer for gears over any spool printer . It doesn't take much of an error to cause a poor fit which will either make it feel rough to turn or not turn reliably. More important for gaming, imo, is backlash. We generally like our controllers to feel responsive without a built in dead zone.
If you already have a decent "high res" 3d printer it's probably worth a try but steel gears are so cheap, I'd still want to use them instead. E.g.:
https://www.speedwaymotors.com/Garage-Sale-Speedway-Super-QC-Gears,3778.html?sku=91955-40&utm_medium=CSEGoogle&utm_source=CSE&utm_campaign=CSEGOOGLE&gclid=EAIaIQobChMIv6Hq4Oq35QIVA4eGCh3ueQQkEAQYAyABEgKIlfD_BwE
« Reply #26 on: October 26, 2019, 07:36:21 pm »
Well the thing you are all forgetting is... it's a 3d printer....  When/if the gears wear out you just print new ones.  There isn't a terrible amount of tension on the star wars yoke, so any wear would be from it getting a lot of use.  The exact tooth size of the gears in those yokes would be difficult to replicate on a typical 3d printer, but the gears don't have to be exact replicas to feel similar.
pixel
  • Last login:December 24, 2019, 05:33:55 pm
« Reply #27 on: October 28, 2019, 04:15:32 am »
 Its NOT about tension with this.  Its about ACCURACY.
 If the gears are not perfectly aligned and meshing... there will be "Play".
 Play equated to two things:
 1)  Slippage or small Non-tracking distances / Premature Wear / Breakage
 2)  Poor Tracking
 The 2nd being the most critical.  If you are trying to move a cursor to pinpoint a target... and the tracking is even a hair off... its going to
seriously impact a persons accuracy.  It would be like trying to shoot a can with a bb-gun... and someone lightly taps the barrel... right
as you are about to pull the trigger.
 The larger the teeth, the less accuracy is required to mesh... but if those gears teeth are not 100% perfectly distanced, then the travel and
play... is going to cause a lack of smooth and accurate tracking... in addition to potential wear and other issues.
 Its likely better to use Resin based 3d printers, rather than these incredibly hacky layer-noodle printers.
 And even then... you likely would want to make a mold of the printed parts, and cast them in metal.
« Reply #28 on: October 28, 2019, 01:16:09 pm »
I've got a cheap 3d printer from China and if you work within the resolution limits and have it properly dialed in you can print stuff almost dead accurate in terms of the size.  You might have to use a larger tooth size, but there wouldn't really be any play.  If that isn't acceptable for you guys go to the local hobby store.  If they have rc vehicles then they most likely have tons of gears for sale.... a similar size with the same gear ratio should be findable and that's really the only two things that matter in this situation.  Hell they sell hobby gears on ebay and amazon.
My point is don't immediately throw hundreds of dollars into a solution for a controller that's really only used for three games..... you have options.  On the other hand getting a Star Wars cockpit for a stand alone solution might make sense as the thing is frikkin gorgeous and you can't really replicate that vector glow.
Mr. Peabody
« Reply #29 on: October 28, 2019, 03:43:38 pm »
Another thing is travel. If the gear size isn't the same, you may not reach the edges of the screen/playfield.
People piss and moan for years on end about not having a yoke. Now someone re-produces them in spades, at the best price in history, and people become turncoats.
@Howard: say what?? Spy Hunter, Outrun, Hang-On.....  The lack of this recognition escapes me.....
« Last Edit: October 28, 2019, 03:46:16 pm by Mr. Peabody »
KenToad
  • Last login:Yesterday at 06:30:59 pm
  • Flap Flap Flap
« Reply #30 on: October 29, 2019, 11:34:24 am »
Spy Hunter and Star Wars Trilogy arcade would be my go to games. OG Star Wars arcade gets old really quick, even back when it was new. I'd rather play Stun Runner or Road Blasters any day.
$350 seems reasonable for a new, high quality yoke.
« Reply #31 on: October 29, 2019, 01:42:32 pm »
Except.... none of those other games mentioned use a star wars yoke.  A few of them use a similar yoke, but if you aren't exact about the controls, then again, my original point stands... unless you need the exact yoke for some reason you have options.  Also unless you are doing like me and using a racing rig that just happens to have a yoke attachment, you'll need pedals and a gearshift and then it's going to be a mess on a standard mame cab.
$350 for any gaming controller borders on ridiculous and a controller that was designed for three games, two of which can be beaten in under 2 minutes is insane.  I totally get that it's high quality, but my point is it doesn't need to be... it won't be in a real arcade.  Heck for 350 the arcade1up cabinet would be a better option.  They've done a good job with this one and the yoke is pretty similar.  It's too short but I believe the deluxe version comes with a riser.
« Reply #32 on: October 29, 2019, 02:10:01 pm »
LeChuck breaks down in as good of detail as I've seen the games other than Star Wars that are playable with a yoke.
http://forum.arcadecontrols.com/index.php/topic,152903.0/all.html
Game list post -
http://forum.arcadecontrols.com/index.php/topic,152903.msg1600918.html#msg1600918
He lists a lot of games that surprised me like Paperboy.
He tested Roadblasters for me and it did not sound like it was playable.  I suspect any game that requires an optical encoder is not going to play well but YMMV.
KenToad
  • Flap Flap Flap
« Reply #33 on: October 29, 2019, 02:25:11 pm »
Hmm, no Spy Hunter in that list. Too many buttons?
Howard, I definitely agree if you're suggesting that the Arcade 1up version of the yoke looks like a potentially good option for those who don't need super high quality. I would pick one up in a heartbeat if they sold them separately with a USB connector.
Zebra
« Reply #34 on: October 29, 2019, 02:49:16 pm »
I guess a lot of it comes down to how much you love a particular game. If it's your fav game of all time, it's worth investing in decent dedicated controls for it. I tend to spend more time and derive more enjoyment from playing games I invested in quality arcade controls for. I never touched Operation Thunderbolt until I got an Op thunderbolt arcade gun. Now, I play it all the time. It's awesome, just not with an Aimtrak.
There is a reason why we like real arcade controls. There are any number of cheap flimsy home peripherals  with cheap plastic gears and anemic force feedback motors etc. We spend extra on real arcade controls because they look and feel right. They use quality metal parts, have strong motors and feel like you could drop a tank on them and carry on playing. It's a key part of the nostalgia.
I think it's better not to buy or build arcade controls at all unless you can do it right with quality components. If you love the Star Wars arcade enough to put the cab in your home, you want the real yoke imo.
If you don't love those games, a cheap used USB flight yoke off ebay is the logical 2nd choice (or not buying any yoke). Does anyone know how many arcade games use a yoke (besides star wars)?
« Reply #35 on: October 29, 2019, 04:19:55 pm »
Wiki has a list of 15 yoke games and a bunch of other analog joystick games that should work well with a yoke.
http://wiki.arcadecontrols.com/index.php/Joysticks#Analog_Joysticks
There are a number of other games that used a 270 degree (potentiometer) steering wheel.  There might be an updated version of this list in the driving sub-forum.   :dunno
http://wiki.arcadecontrols.com/index.php?title=Spinners_and_Dials#Steering_wheel_.28potentiometer.29_games
That would be my guess.
The yoke can easily handle steering and 4 buttons. (machine guns, smoke screen, oil slick, missiles)
If you don't have an analog pedal, you could map that to the yoke Y-axis.
In addition, you would need a Weapons Van button (or a Start button) and a high/low Gear Shift. (or 1 other button)
Zebra
« Reply #36 on: October 30, 2019, 12:08:04 pm »
15 is decent if you like all those games. I can't honestly say I'd ever play any of them myself though. I assume you could also use a Star Wars arcade yoke for regular PC flight syms although there are probably better yokes for serious flight training.
I'd only invest $300-$500 on a Star Wars yoke if I was building a dedicated star wars cab. I think something like this would make a better multi-purpose analog controller:
https://www.betsonparts.com/jurassic-park-complete-gun-assembly.html
It would work as an arcade yoke and for positional gun games. Plus adding recoil to games like Star Wars would breath some new life into a fairly dated looking games. I love the double-solenoid recoil mechanism in these Jurassic Park (Raw Thrills) and the new Space Invaders game guns. It would work very well as a space ship gun.
negative1
« Reply #37 on: November 06, 2019, 08:55:25 pm »
just for reference, here are some other games that can be played with the star wars yoke:
later
-1
tommyinajar
« Reply #38 on: November 22, 2019, 08:29:02 pm »
 I am sure I already know the answer- Any way to reasonably mod a road riot 4wd wheel (Road blasters) to a StarWars yoke?
I already know I'm buying this, now who is making vector monitor reproductions.....
 :P
« Reply #39 on: November 22, 2019, 11:24:47 pm »
 :P
I tried using a Hydra yoke and was not happy with the results.  I would suggest just sticking with a Star Wars yoke.
