Author Topic: J-PAC not saving upgraded firmware  (Read 1664 times)
ipokesnails
  • Last login:September 07, 2019, 01:15:24 pm
« on: September 07, 2019, 01:11:53 pm »
I have a J-PAC in my Korean DDR cabinet hooked up to a computer running Windows 10.
None of the inputs worked, but upgrading the firmware using WinIPAC made it function perfectly.
Occasionally when I boot up the computer, all the arcade buttons will continue to work properly.  Sometimes when I boot the computer none of the arcade buttons work, and when I run WinIPAC it shows that the firmware has reverted back to the original version.
Is this normal behaviour, or am I not upgrading the firmware properly?
« Last Edit: September 07, 2019, 01:16:14 pm by ipokesnails »
Mr. Peabody
  • Last login:November 11, 2025, 07:08:52 pm
Re: J-PAC not saving upgraded firmware
« Reply #1 on: September 09, 2019, 10:12:09 pm »
Not normal. I don't know how that could happen - except that Win10 is doing some driver re-set. Check the Windows event log.
« Last Edit: September 09, 2019, 10:16:38 pm by Mr. Peabody »
