Author Topic: Pole Position Gear Shift - Am I set up correctly?  (Read 5011 times)
funbobby
  • Last login:September 09, 2022, 12:16:31 pm
« on: September 05, 2019, 09:58:56 am »
Hey Guys,
I am using the original Pole Position controls along with the U-HID board.  I still have the original controls (so a single switch on the gear shift).  I have flipped the TOGGLE option to NO, and configured the U-HID to send a constant keypress when closed, then clear it out when not closed.  This works great because it never gets confused between High/Low gear.  I've noticed if I leave the gear shift in the closed position when I walk away from the machine, after a while it freezes and stops running the 'Attract Mode'.  I simply re-start it and everything is fine, but I'm pretty sure the issue is because it's the equivalent of pressing the spacebar down for an hour.
 I've read many older threads where people suggest/beg for the ability to map high/low to two different keys, but I haven't read where that is currently available.
I just wanted to double check that I'm using the latest features available to make the original controls work as realistically as possible and I"m not missing something.
baritonomarchetto
  • Last login:March 02, 2026, 07:09:37 am
Re: Pole Position Gear Shift - Am I set up correctly?
« Reply #1 on: September 07, 2019, 10:27:23 am »
Change the keypress the u-hid emulates when your shifter switch close (you said spacebar, right?) and you should be good to go.
What do you mean when you say 'I have configured the u-hid to send a keypress when closed'? There should be no need for "special" configurations if the shifter in mame is set to 'no toggle'
funbobby
« Reply #2 on: September 09, 2019, 02:45:10 pm »
I just mean that the keypress in u-hid is NOT set to pulse....so it acts as a constant keypress....as if you're holding a key down.   With Toggle set to NO, I couldn't figure out another way to do it.
baritonomarchetto
« Reply #3 on: September 10, 2019, 12:36:08 am »
Ok, I suppose that's the correct choice. "Pulse" is likely PWM of some sort (I am not used to commercial "arcade" boards like U-HID, but Arduino ;) ).
Try changing the mapping of the shifter switch then.
  • Online Online
  • Last login:Today at 11:26:05 am
« Reply #4 on: September 10, 2019, 02:43:23 am »
Pulse option sends one short keypress when the shifter switch is closed.
http://www.u-hid.com/home/u_config_utils.php
Pulse Primary
This sends a short pulse, simulating the key being pressed then released, even though it might still be physically closed (eg a toggle switch left closed)
[I couldn't figure out another way to do it.
Have you tried changing it to a gamepad button output?
Important Note about keyboard keycodes: On USB keyboards (and therefore the U-HID) the auto-repeat of the keyboard is done in Windows. So if you assign any keycode to be pressed permanently (which can occur in many configurations) you will get an endless string of characters in your application. For this reason, many of the advanced combinations should only be used with gamepad buttons, which do not have a problem being held in the pressed position.
You should also avoid defining any keyboard keys from being "pressed" by default as this will cause boot failures (stuck key) and may cause unexpected problems in the Windows GUI.
funbobby
« Reply #5 on: September 10, 2019, 08:50:20 am »
I'll definitely experiment some with changing it to gamepad.  I had read the warnings about the constant keypress a while ago,  and that describes exactly what's happening  (Windows doesn't like the constant keypress)  but didn't pick up on the fact that a button press worked differently than standard keyboard input.  Thanks!
funbobby
« Reply #6 on: September 12, 2019, 09:53:09 am »
Thanks again for the help.  Changing it to a gamepad button worked perfectly.  Everything still works perfectly and Windows doesn't crash.
  • Online Online
« Reply #7 on: September 12, 2019, 10:36:44 am »
Glad to assist.   :cheers:
baritonomarchetto
« Reply #8 on: September 12, 2019, 11:17:20 am »
Good work!
