Author Topic: JVL Vortex Problem Not booting "No Signal"  (Read 10005 times)
McArcade
  • Last login:September 04, 2019, 12:38:33 pm
« on: September 04, 2019, 07:11:23 am »
Thank you in advance for any help.
I have a JVL Vortex that all the sudden shows "No Signal" for a few seconds on the screen and repeatedly trys to boot.  The last thing it says before trying to boot again is "press shift F-10 to configure".
Does this sound like a hard drive problem?
Any help is much appreciated.
Thanks again
mahkeymike
  • Last login:January 15, 2026, 03:00:29 pm
Re: JVL Vortex Problem Not booting "No Signal"
« Reply #1 on: September 04, 2019, 02:46:22 pm »
yeah bad CF card. What itouch version?
  • Last login:January 19, 2026, 06:58:37 pm
« Reply #2 on: September 04, 2019, 02:47:52 pm »
could be a bad CF card. they are getting pretty old. i've had to swap a few out
you can also remove the computer motherboard and remove/reinstall the ram,flashcard and see if that smartens it up...check the board for capacitors with bubbled tops...they will need to be replaced.
your power supply might be going south... lots of times the capacitors go bad on those and let tons of ripple into the computer causing all sorts of issues.
docpoof
  • Last login:November 27, 2025, 09:31:16 am
  • Xbox modder
« Reply #3 on: September 10, 2019, 04:38:25 pm »
Let us know how you made out.  I have the same exact issue with my retro.   :timebomb:
