Author Topic: How to run a cable into a project box and clamp it in place  (Read 2350 times)
thorr
  • Last login:August 02, 2024, 02:56:08 pm
« on: August 28, 2019, 03:42:27 am »
Hello, I am working on several projects that require running cables into plastic project boxes, including potentially building some handheld USB joysticks.  If I have a plastic case with a screw on lid, I can drill a hole where the two parts meet and run a USB cable through the hole.  However, it can slide back and forth.  What do I need to clamp the cable in place so it does not move.  A grommet wouldn't help because it doesn't hold the cable in place.  Maybe a grommet with hot glue on the inside of the case?  I also thought of putting clamps on the inside and the outside but that would take up a lot of room and look bad.  Any suggestions would be appreciated.  My current joystick that I built had a panel mount USB port, but the cable kept getting disconnected when I was playing.  I ended up removing the panel mount and running the cable through the large hole and tying a knot so it wouldn't come out, but it is still loose.  I want a permanent cable solution that doesn't unplug from the joystick and looks nice.
Laythe
  • Last login:February 04, 2026, 08:00:11 pm
Re: How to run a cable into a project box and clamp it in place
« Reply #1 on: August 28, 2019, 04:07:47 am »
I believe the term-of-art that you are looking for here is, "Strain Relief".
As a search term, that should get you what you seek.
thorr
« Reply #2 on: August 28, 2019, 04:24:09 am »
Thanks!  Something like this?  https://www.amazon.com/eBoot-Plastic-Waterproof-Adjustable-3-5-13mm/dp/B01GJ03AUQ?ref_=fsclp_pl_dp_13
With a product like that, the main issue is having to cut the USB connector end off to fit the cable through the hole, then resolder the connector back on.
« Last Edit: August 28, 2019, 04:41:35 am by thorr »
big10p
  • Last login:May 01, 2023, 01:46:23 pm
  • Mmmm, arcade classics!
thorr
« Reply #4 on: August 28, 2019, 04:46:55 pm »
Thanks!  That is a good idea about the cable tie / zip tie.  I saw they also have split grommets.  If I put it where the lid meets the body, it could pinch the cable a bit, so that might be another option along with the zip tie.  I could also put a zip tie on the outside, but that wouldn't look as nice.
big10p
« Reply #5 on: August 31, 2019, 09:58:02 am »
You won't need a zip tie on the outside, as that will just stop the cable from being yanked into the box, which won't be an issue when it's all fitted together.
testicle187
  • Last login:January 24, 2026, 06:08:15 pm
« Reply #6 on: September 01, 2019, 12:55:54 pm »
Tie the cable in a knot on the inside and hot glue in place.  That is how most cables are secured from the inside.
