Author Topic: Visual Pinball Wrapper problem...  (Read 2296 times)
Pat S
  • Last login:May 23, 2005, 12:16:11 am
  • I'm not a llama!
    • Cab pics...
« on: February 14, 2004, 05:29:59 am »
Hi,
I'm having trouble running the
New! Visual Pinball Wrapper 3.0 Suitable for Visual PinMame Beta 1.20
When I run the vplaunch2.exe and the configuration menu pops up, I try to run a table, and I get a black screen that cannot be cancelled and I have to reboot.  If you alt-tab, the black screen comes right back.
I'm running Windows XP, and the tables play fine the regular way.  I'm using Pinmame Version 1.31 and Visual Pinball tech beta 6.  Maybe the wrapper does not work with these newer versions?
Are their any support files for the wrapper I could re-install, like dll's, VB6 or anything?
Thanks for your time,
Edgedamage
  • Last login:October 06, 2018, 12:21:23 am
Re:Visual Pinball Wrapper problem...
« Reply #1 on: February 14, 2004, 07:41:13 pm »
Try VPlauncher never failed on me.
Curls in the squat rack !?!?!
Pat S
  • I'm not a llama!
    • Cab pics...
« Reply #2 on: February 14, 2004, 08:54:34 pm »
Thanks, didn't know that existed, I'll give it a shot.
Pat S
  • I'm not a llama!
    • Cab pics...
« Reply #3 on: February 14, 2004, 09:23:39 pm »
I got the program to work ok, is there any way to get mamewah to launch a game with it without having to go the program?
imovaherenow
  • Last login:January 08, 2006, 09:07:06 pm
« Reply #4 on: February 15, 2005, 11:35:45 am »
I'd like to know too.. Thanks...
  • Last login:Yesterday at 02:10:08 am
Re: Visual Pinball Wrapper problem...
« Reply #5 on: February 15, 2005, 05:22:52 pm »
Hi,
imovaherenow
« Reply #6 on: February 16, 2005, 11:06:08 am »
I'm not sure where you got that from, but that wrapper has been outdated for some time.
« Reply #7 on: February 17, 2005, 12:36:31 am »
stick it in the tables directory.... point mamewah to the wrapper instead of the vp exe.
Your done
imovaherenow
« Reply #8 on: February 17, 2005, 12:17:37 pm »
Below is part of my ini for mamewah... when i try to run a pinball game from mamewah i get a window that has all my  pinball games listed ... but how do i get it to run the game... Also when it does runt he game the game says factory settigns reset andi t won't let me play...
### vpinball.ini (mamewah v1.61) ###
emulator_title                            PinBall
### List Generation Settings ###
rom_path                                  c:\vpin\Tables
rom_extension                             vpt
dat_file
nms_file
catver_ini_file
list_generation_method                    rom_folder
### Execution Settings ###
emulator_executable                       c:\vpin\Tables\VPLauncher.exe
commandline_format                        [name]{autodosbox}{nosafelaunch}
alt_commandline_format_1                  [name]{autodosbox}{nosafelaunch}
alt_commandline_format_2                  [name]{autodosbox}{nosafelaunch}
game_specific_config_path
### Artwork Locations ###
« Reply #9 on: February 17, 2005, 05:02:31 pm »
umm you are pointing it to vplauncher, which is a visual pinball front end done by data dragon.
You can use vplaunch.exe as a front-end, but not as a way of automatically launching visual pinball tables.
You should have my vp wrapper (4th version) and point it to:
vp-launch4.exe
which should be in your tables directory of course.
The fact that the two completely unrelated programs have similar exe names is confusing I'll admit.  But since my wrapper actually launches the games while the vp launcher program simply lists them (allow you to launch)  mine is more correctly named, and thus I'm not changing it.  ;)
imovaherenow
« Reply #10 on: February 23, 2005, 05:17:14 pm »
Again..
Below is part of my ini for mamewah... when i try to run a pinball game from mamewah now i get nothen mamewah flashes the name of the pinball table i want to play on top of the menu then it returns to the menu. but how do i get it to run the game...
rom_extension                             zip
dat_file
nms_file
catver_ini_file
emulator_executable                       c:\vpin\Tables\VP-Launch4.exe
imovaherenow
« Reply #11 on: February 23, 2005, 05:31:02 pm »
Again..
emulator_title
