Author Topic: looking for unstupids ms pacman cocktail table plans for cnc  (Read 21497 times)
abispac
  • Last login:March 01, 2026, 10:21:07 pm
« on: August 23, 2019, 08:51:48 pm »
As the tittle says, i just restored a supercobra cocktail table and converted it to a retropie game and it came out good, now i would really like to get one for myself so here at my city there is a guy that charges me 45 dlls to cnc any 4x8 plywood , so i really really would apreciate if someone has those files for cnc ready, that would be awesome, thanks for any help . Unstupid site is down and he hasn't logged in in a year or more. So hope someone can help, thanks.
  • Last login:Today at 12:18:48 pm
Re: looking for unstupids ms pacman cocktail table plans for cnc
« Reply #1 on: August 23, 2019, 09:40:22 pm »
Are you talking about this file?
You can download the MCX file here...  http://www.unstupid.com/myfiles/MsPacCocktail.zip
A few notes:
- There is no table top piece.  That was cut separately on a 1" piece of ply.  Although there is space for the tabletop on this sheet if you are ok with it being 3/4" thick
There are 5 tool changes.
1- 1/8" flat bit to drill bolt holes for the vents and speaker grills also to cut out the C14 receptacle.
2- 1/4" chamber bit to scribe the lines where i need to drill 3/8" holes with the doweling jig in the side of the plywood
3- 1/4" flat bit drill out the 3/8" holes for the dowels (using a helix bore toolpath)
4- 3/8" compression bit to cut the holes, coindoor and finally the panel edges
5- 1/8" flat to clean up the inside radiuses on any internal 90degree cuts.
Archive.org has it.   :cheers:
https://web.archive.org/web/20160815000339/http://www.unstupid.com/myfiles/MsPacCocktail.zip
abispac
« Reply #2 on: August 24, 2019, 01:21:16 pm »
 :burgerking: that's the one, thanks slot man
  • Last login:Today at 12:10:15 pm
« Reply #3 on: January 21, 2022, 06:25:38 pm »
Did this work?  Did you ever get these plans cut and assembled?
  • Last login:Today at 02:41:12 pm
« Reply #4 on: January 21, 2022, 07:05:28 pm »
Are you sure you want to ask sir hacks-a-lot for his input?
« Reply #5 on: January 22, 2022, 11:25:22 am »
I've been thinking about a Midway cocktail for a project this year... not sure where to start.  eBay and Craigslist are ridiculous wanting like $2000 for completely trashed cabinets.  I have the Kyle Lidstrom plans but not sure I'm up for building it from scratch myself.  I could do it but it would take a lot longer than I would want it to take.  All the flat packs I've seen online aren't accurate.  Arcadeshop sells one but it has been out of stock forever.  Haruman makes one but it's out of 1/2" material.  So I'm just poking around... perfect CNC plans would be nice if I can find someone local to cut it out.
bobbyb13
  • Last login:February 21, 2026, 01:34:49 am
« Reply #6 on: January 22, 2022, 11:48:48 am »
If you already have a tube to work with then design your own and cut it by hand!
Yes, you can...
« Reply #7 on: January 22, 2022, 12:13:53 pm »
Yes, you can...
It's a nice thought but I want an "original" Midway for this project.  Could be a replica but it would have to be very accurate.  Other than a DK, which I already have, it is my (extremely common) holy grail.  We used to go to Lake George for vacation with my grandparents when I was a kid and the smoke-filled lounge had a Ms. Pac-Man that I would pump quarters into for a week straight every summer.
bobbyb13
« Reply #8 on: January 22, 2022, 03:27:00 pm »
No way-
My mom's family is from Port Henry/ Mineville area so I know the zone.
I may have been to that same joint in Lake George!
We'd hit the Great Escape once a summer too on our way up from MD and CT.
I do like the idea of the simplicity of an original cabinet also.
I wonder how much it would cost to get one of what Scott unearthed cut.
Maybe someday!
abispac
« Reply #9 on: February 02, 2022, 12:14:55 am »
Im glad you follow my topics, and im also glad you call me mr hacks-alot. I 100% enjoy everything i do. Life dont have to be perfect.
abispac
« Reply #10 on: February 02, 2022, 12:18:38 am »
Hey sorry , but this is an old old topic i didnt knew it needed my atention. Anyway, i ended up  using https://www.classicarcadecabinets.com/galaga-cocktail.html plans, the only downsize is they are like a bit smaller than the original design, still a good size cab, fits a 19/21 monitor withuot the frame. I built like 5 cabs with those plans, they all came out perfect. If you decide to use this plans, keep in mind they are also designed for 1/2 inch wood, since i used 3/4 i had to modify the sides of the control panels holders to be 1 inch more tall, so the joystick would not get stuck with the glass. My english is limited so let me know if you need more explanaition.
« Last Edit: February 02, 2022, 12:21:32 am by abispac »
