Author Topic: golden tee fore trackball no left or right  (Read 2094 times)
gmtransman2
  • Last login:August 27, 2022, 10:10:37 pm
« on: August 18, 2019, 12:28:13 pm »
i have a golden tee complete that the track ball does not go left or right. up and down is fine. i have tried a new track ball and harness and still same problem. what else can i do ? is the board bad. thanks
hoppdrop
  • Last login:December 06, 2019, 06:30:44 am
Re: golden tee fore trackball no left or right
« Reply #1 on: December 06, 2019, 06:29:35 am »
Have you found the problem yet?
I am having the same problem.
nexusmtz
« Reply #2 on: December 07, 2019, 02:27:21 am »
Open the trackball, see if the two optical boards inside are identical, and swap them if they are. If the problem switches from horizontal to vertical, you have a bad optical board.
