Author Topic: 2005 Golden Tee CRT Issues  (Read 2134 times)
Wavfact
  • Last login:March 13, 2025, 08:23:09 am
« on: August 08, 2019, 09:11:01 am »
I am having an issue with the monitor in my 2005 Golden Tee..  See pictures below...  Is this monitor dead or can it be saved?
grantspain
Re: 2005 Golden Tee CRT Issues
« Reply #1 on: August 08, 2019, 09:28:06 am »
you have two faults on that
partial vertical collapse- could be caps/vertical deflection ic
green missing- likely transistor or broken track on neck card
Wavfact
« Reply #2 on: August 08, 2019, 09:30:16 am »
Is it worth the effort to fix?
grantspain
« Reply #3 on: August 08, 2019, 10:12:30 am »
depends how good you are at soldering and fault diagnosis, the worry could be a bad tube- you go to all that effort and find the green gun is bad, so perhaps look at the green fault first
Wavfact
« Reply #4 on: August 08, 2019, 10:16:10 am »
My soldering skills are quite good... but CRT diagnostics.. not so much.. lol
Might see if there is a local shop who can take a look..
