Author Topic: Question about other emulators  (Read 989 times)
jedimason
  • Last login:May 16, 2007, 08:33:54 pm
  • I've just sucked one year of your life away.
« on: February 13, 2004, 02:34:12 pm »
I'm using mamewah as my front end and have several different systems on my arcade.
I'm using virtuanes to play my o.g. nes games.
On certain games when I run the emulator, a windows dialog box comes up saying that "this is an illegal header in the rom" do you wish to continue".  If I hit okay, everything starts up fine.
It's obviously something the coders put in there.  Can I disable it.  The games run fine after I hit okay, but it is an annoyance.
Thanks for the help
TalkingOctopus
    • My Arcade
Re:Question about other emulators
« Reply #1 on: February 13, 2004, 04:02:31 pm »
It says that because you have a bad version of the rom.  Unfortunately, there are so many NES roms floating around it is hard to have a verified good version.  When I get that message, the rom will not work most of the time.  I think the only solution is to download a new version of the rom.  I don't believe there is a way to disable the message.
