Author Topic: Wells Gardner D9400 vertical is off. Looking for help  (Read 8166 times)
vargas14617
  • Last login:February 14, 2024, 02:56:54 pm
  • Don't push the Red button! I pushed the Red button
« on: August 01, 2019, 09:25:13 pm »
Just purchased a americas army arcade. When i got home the image shifted down and I dont know what to do.
grantspain
Re: Wells Gardner D9400 vertical is off. Looking for help
« Reply #1 on: August 02, 2019, 12:03:18 am »
have you tried to adjust the picture using the remote board, its normally inside the coin door to one side on some velcro
vargas14617
« Reply #2 on: August 02, 2019, 06:16:30 am »
Thank you for the reply. Yes this is with the adjustment at 100 max.  Won’t go up anymore
grantspain
« Reply #3 on: August 02, 2019, 06:27:18 am »
i don't think the yoke has dropped otherwise you would have purity and convergence issues
maybe try factory mode, to enter the factory menu turn the monitor off. Hold the buttons 'OSD' and 'Key +' and turn it on- i think this is correct, its been a long time since i did this
vargas14617
« Reply #4 on: August 02, 2019, 07:49:01 am »
Thanks will try when i get home from work
grantspain
« Reply #5 on: August 02, 2019, 09:46:08 am »
you do have one other option if that don't work- connect a keyboard and mouse, once game has booted press windows key and then shut down gvr then mouse right click the screen anywhere and use nvidia settings to adjust it
vargas14617
« Reply #6 on: August 04, 2019, 09:45:50 pm »
I got into this menu but it did not help.  Do you know where I can get the default numbers because I messed up the sides.  I don't think its a collapse because the bottom goes beyond the screen. the other suggestion did not work.  I appreciate your help.  any other suggestions?
grantspain
« Reply #7 on: August 05, 2019, 01:55:44 am »
there are aren't any default numbers as such, how did you mess the sides up unless you restored factory settings which is not the same as accessing factory menu
accessing factory menu gives you more adjustments and greater ranges
anyway post a photo of a screen shot and i can tell you what to adjust
vargas14617
« Reply #8 on: August 05, 2019, 09:22:34 pm »
So this is what the picture looks like now. I reduced it to show the sides
« Last Edit: August 05, 2019, 09:24:21 pm by vargas14617 »
grantspain
« Reply #9 on: August 06, 2019, 01:41:27 am »
so that looks simple enough to me
trapezoid
pincushion
vertical shift
vertical size
horizontal size
vargas14617
« Reply #10 on: August 06, 2019, 08:02:34 am »
Thanks for quick reply. Will give it a try
vargas14617
« Reply #11 on: August 06, 2019, 10:48:21 pm »
trapezoid
pincushion
vertical shift
vertical size
horizontal size
Thanks worked. Just still have to figure out original problem
grantspain
« Reply #12 on: August 07, 2019, 02:37:13 am »
do the vertical size and vertical shift both work
vargas14617
« Reply #13 on: August 07, 2019, 06:19:00 am »
yes the vertical size increases size but mostly the bottom of image just keeps going down. Shift moves imGe up or down and maxes at 100 but does not reach top.
grantspain
« Reply #14 on: August 07, 2019, 12:45:41 pm »
its possible there may be an issue in the vertical deflection circuit
what happens if you adjust vertical linearity?
vargas14617
« Reply #15 on: August 07, 2019, 09:37:37 pm »
How do i do that?
grantspain
« Reply #16 on: August 08, 2019, 03:35:03 am »
How do i do that?
like i said it years since i adjusted one but i think its first left second line down on the factory menu
vargas14617
« Reply #17 on: August 09, 2019, 08:17:40 am »
Thank you.
vargas14617
« Reply #18 on: October 02, 2019, 09:18:39 pm »
Was told today that its not deflection. They think its software. Is that possible?
Mr. Peabody
  • Last login:February 12, 2026, 12:32:17 am
« Reply #19 on: October 05, 2019, 04:29:48 pm »
You have a weird image there. Like a piece of paper curved on itself in the upper area. That alone suggests hardware to me. That is displays it the bios screen says more so.
