Author Topic: JAMMA + VGA converter WIREUP  (Read 1249 times)
acid2k1
  • Last login:July 31, 2019, 04:31:38 pm
« on: July 31, 2019, 03:48:59 pm »
Hi,
Sum up I need guidance on how to hook up a VGA converter to a JAMMA board (I will be using an LCD and not CRT). I have looked around but most the information I found is showing the device in action and not the setup part (maybe i'm not looking hard enough).
The cables I had with the VGA converter is a 8pin (RED, GREEN, BLUE, GREY, YELLOW AND BLACK) & a 2pin ( RED & BLACK).
I'm starting with a fresh CAB and not an existing CAB (If that is relevant)
Thank you!
