Author Topic: Crt Emudriver with flickering filter on future version ?  (Read 2360 times)
m.andrade1
  • Last login:April 10, 2025, 09:05:35 am
« on: June 17, 2019, 01:58:43 pm »
Hello Calamity
Can you provide both version on futures releases of Crt Emudriver, the tradional with flickering just as it is on beta 15, and another with flickering filter on, just like it was on beta 10.
I just want to test composite sync, but i´m stuck on beta 10 because i preferer flickering filter as i´m using a RGB osd mod, the image is much better with flickering filter on.
Thanks a lot
Marcos
Calamity
  • Moderator
  • Last login:Yesterday at 05:35:07 pm
  • Quote me with care
Re: Crt Emudriver with flickering filter on future version ?
« Reply #1 on: June 18, 2019, 06:18:11 am »
Hi m.andrade1,
I'm not planning to mantain two versions of the driver, since it'll make things too complicated to handle. Too many people hated the filter unfortunately.
However, in the future the way CRT Emudriver is released might change, and instead of releasing a full package I might provide it as a configurable patch. Not sure if this will ever happen though.
Steps to create a log:
m.andrade1
« Reply #2 on: June 18, 2019, 09:19:05 am »
Hello Calamity
Will be great if you could return that fearture on future release, because on regular Tv sets when you do the RGB mod thru OSD, the image is excelent with Filter flicker on, but when you use without it makes my had explode it flickers so much.
So if you can do a patch or a alternative version, will be extreme glad.
Thanks a lot !
Marcos
