Author Topic: way to skip compiling?  (Read 1227 times)
jam92102
  • Last login:May 10, 2013, 07:02:22 pm
  • Help Me Please!!!!
« on: February 12, 2004, 09:45:52 pm »
Hi all.  I'm in the middle of compiling mame056 for dos.  It keeps crashing at the same spot (compiling drawgfx.c).  I've restarted numerous times and have even typed in make MAMEOS=msdos a total of ten times in a row!  It keeps crashing at that spot!  Is there anyway to tell the compiler to move on past that?  Like a skip command or something?  I'd appreciate any input even if it's to say how bad I suck at this, as long as you can help also. :)  Thanks!
jerryjanis
  • Last login:February 02, 2023, 01:56:44 am
  • Skate or Die!!!
    • Jake's Joystick
Re:way to skip compiling?
« Reply #1 on: February 13, 2004, 03:39:47 am »
Just a guess, but "drawgfx.c" kinda sounds like an important part of the Mame - you probably don't want to skip it.
I've never compiled the DOS version, but if your compiler is crashing then you should probably check to make sure that you are using the correct version of the compiler & related software for such an old version of Mame.
abrannan
  • Last login:July 25, 2012, 11:32:14 am
  • Building a cabinet in perpetuity since 2002
« Reply #2 on: February 13, 2004, 11:18:40 am »
I'm guessing you made changes and downloading the binary isn't an option?
If no one feeds the trolls, we're just going to keep eating your goats.
nipsmg
  • Last login:Today at 02:38:40 pm
  • ROONEY!! ERRGH!!
    • Arcadia
« Reply #3 on: February 13, 2004, 11:36:49 am »
Try typing MAKE CLEAN.
then type MAKE.
This will clear all old objects and start a clean recompile.. yes it will take longer because you have to complie ALL of the files again, but it helped clear up some funky complie errors I had.
--NipsMG
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #4 on: February 13, 2004, 11:26:35 pm »
are you using the right compiler with the right libraries for the time period 56 came out?
jam92102
« Reply #5 on: February 13, 2004, 11:50:08 pm »
Well I was going off of the compiling directions for dos on mame.net and used that version of mame on that page which I believe is 56.  I didn't know that you could get by without compiling by just downloading a certain release b I think it is?  Anyways I just went that route.  Thanks for all the help everybody.  I really appreciate it.
