Author Topic: Another Hantarex polo 25-28 repair (SOLVED)  (Read 3410 times)
perjmolsen
  • Last login:December 08, 2022, 04:09:06 am
  • I want to learn, and try.. I NEWER give up :)
    • My gameroom
« on: June 17, 2019, 12:45:31 pm »
Hi
I got my fingers in another hantarex Polo 25-25 that I am trying to repair..
When i got the chassis the NTC and fuse where blown, NTC and Fuse replaced
- I have checked all the diodes in the PSU selection, all are OK.
- Zener diode is OK
- Checked the two large resistors they are OK.
 - T101 is OK
- HOT is OK
-Changed the large 220uf 400V cap and also C111, C112 and also the poly caps C104 and C105
- Also removed the solder at flyback pin3 and1 - and connected a  40w bulb to chassis ground. 0 V at TP6
So stepped back to TP1...there is 0V at TP1?
Where is my volts at TP1?
« Last Edit: June 19, 2019, 05:52:27 am by perjmolsen »
perjmolsen
    • My gameroom
Re: Another Hantarex polo 25-28 repair
« Reply #1 on: June 17, 2019, 03:31:23 pm »
Found a bacd trace in the PSU section.. now i have B+ over 200V!
(with  HOT removed the solder at flyback pin3 and1 - and connected a  40w bulb to chassis ground)
Changed C112 + C114 still HIGH B+ at 200V and unable to turn it down  :dizzy:
perjmolsen
    • My gameroom
« Reply #2 on: June 17, 2019, 05:39:56 pm »
A broken trace more in the PSU selection where the issue.
Now i can adjust it down to 145V .. but the R167 went up in smoke.. thinking that mig have been to the high B+ earlier?
perjmolsen
    • My gameroom
« Reply #3 on: June 18, 2019, 03:36:28 am »
Will try to check the tda1675a later today...
perjmolsen
    • My gameroom
« Reply #4 on: June 18, 2019, 08:28:06 am »
Put in a new tda1675a and a new C139
Now the R167 does not get hot anymore  :applaud:
Put it all together, tested my voltages they are spot on  :applaud:
TP6   145
TP10   11.92
TP8   26,7
TP9   16,5
But I have a collapsed picture, so tested
TP31 0V
Test before R167 25V
So I got a blown  R167   (2R7)
I Think that i blew up before i changed the tda1675a (it smoked)
So I am waiting for some new 2R7 resistors... then hopefully a working chassis! :notworthy:
perjmolsen
    • My gameroom
« Reply #5 on: June 18, 2019, 03:45:30 pm »
Found a 2R7 in my spare parts
Now there is picture!!!!!!!!!!!!  :applaud: :applaud: :applaud: :applaud: :cheers:
Just need to have the with of the picture adjusted, but there is no control for the with of the picture, i can only adjust it from side to side... hmm
princess prin prin
  • Last login:Yesterday at 05:06:44 pm
  • intrinsically safe
« Reply #6 on: June 19, 2019, 05:23:19 am »
H AMP doesn't work? That's what adjusts the size.
perjmolsen
    • My gameroom
« Reply #7 on: June 19, 2019, 05:51:53 am »
Hi
Yes the H amp worked  ::)
The first time when i tried to adjust it, it did not seem to work at all... tried one more time and now the picture is perfect :)
perjmolsen
    • My gameroom
Re: Another Hantarex polo 25-28 repair (SOLVED)
« Reply #8 on: June 19, 2019, 05:55:07 am »
Just for later if someone has the same problem:
Parts checked OK:
d102
d103
d104
d105
d106
d107
d108
d109
d110
d111
d112
zd101
d116
d117
d118
d119
t101
T114
R110
R115
d127
Parts changed:
r103 ntc 20e
c104 220nf 250n poly
c105 47nf 250v poly
c108 220uf 400V
C111 220uf 25v
c112 22uf 50v
C114 22uf 50v
R167 2r7
IC103 tda1675a / vertical ic
C139 1000uf 35V
perjmolsen
    • My gameroom
« Reply #9 on: June 21, 2019, 12:34:34 pm »
Just some final notes
I got rasterlines between pictures. ->
Changed first C172, c174 but no real change
Changed R36 and R235 and the issue where gone! ->
