Author Topic: Ipac2 150a firmware  (Read 1201 times)
SpaceNinja
  • Last login:June 22, 2019, 07:17:10 pm
    • Keyboard2Xinput with thumb stick support
Ipac2 150a firmware
« on: June 15, 2019, 09:06:29 pm »
Any one play with the new 150a firmware? It allows you to configure the ipac2 as a dinput or xinput controllers. It's pretty sweet so far. I am running into a little issue though. I am trying to use mode 4 to use dinput but configure input 1a and 1b to be mouse buttons but it will only work in mode 1 even though the firmware guide says it should work in mode 4. Has anyone else tried this? Is there a little trick to get it going or something?
http://www.ultimarc.com/download.html
http://www.ultimarc.com/MultiMode.pdf
http://www.ultimarc.com/IPAC2_150a.zip
