Author Topic: Best Way to Improve Button Consistency?  (Read 2582 times)
Dallinj
  • Last login:June 24, 2021, 09:50:26 pm
  • Boise, ID
« on: June 15, 2019, 06:58:22 pm »
I've got a dozen IL convex buttons w/ 50 gram microswitches (these to be exact: https://paradisearcadeshop.com/home/controls/buttons/il-industrias-lorenzo/il-psl-lcv-series/898_il-psl-lcv-convex-button-clear-white-black-plunger) that all have issues with consistently triggering the microswitches. They're 100% consistent when pressed from the side that lines up with the actual switch (ie: right side) but the other side is only 25% consistent when pressed down. Is there any easy solution to this issue? I was thinking a tiny dab of hot glue on the plunger could fix it but that's more of a last resort. Any help?
  • Bitches love Centipede
Re: Best Way to Improve Button Consistency?
« Reply #1 on: June 15, 2019, 08:20:43 pm »
Press the middle?  :dunno
%Bartop
Dallinj
  • Boise, ID
« Reply #2 on: June 15, 2019, 08:41:36 pm »
 :notworthy:
I meant it more as the left half of the button, and the right half of the button, so when pressed directly in the middle it kinda splits the difference and triggers 75% of the time.  I know it's a dumb question  :laugh2:
« Reply #3 on: June 15, 2019, 09:17:52 pm »
Honestly, I think it's those cheap ass microswitches. I use concave buttons... wouldn't think there'd be much of an issue with convex plungers, though.
%Bartop
Mr. Peabody
  • Last login:November 11, 2025, 07:08:52 pm
« Reply #4 on: June 17, 2019, 05:47:46 pm »
50 grams.....je-sus. Whether you stay with that resistance, try different switches as mentioned.
I have experienced the greatest performance with Sanwa flat plunger buttons. Those are half-height. Longer plungers have greater 'sway'. No buttons are built to have straight travel, as that would require tighter tolerance, hence at best a modified design, possibly lube to prevent resistance, or different material(s) that is self-lubing.
None of that make sense, Mike A?
« Last Edit: June 17, 2019, 05:50:16 pm by Mr. Peabody »
  • Last login:Yesterday at 03:21:17 pm
« Reply #5 on: June 17, 2019, 05:57:48 pm »
Your translator did a good job.
