Author Topic: ClappCade - The ridiculous and inefficient newbie build  (Read 9112 times)
TheDistrict
  • Last login:November 04, 2023, 10:59:16 pm
« on: June 09, 2019, 06:23:42 pm »
Hi All,
A little late to posting here (this has been a work in progress) Started going down the rabbit hole in January.
Take a look at this post to see where I started:
http://forum.arcadecontrols.com/index.php/topic,159180.msg1674047.html#msg1674047
After a ton of research and a lot of trial and error, I have found some time to post the project announcement.
I have decided to go down the path of a somewhat nontraditional cabinet build. Im also not a “handy” person so I had to teach myself how to do all of this for the first time. For those of you who love strange / super-inefficient builds where some newbie does everything wrong the first time around you are in the right place.
Also, I will get this out of the way up front… I fully realize this is ridiculous and probably more expensive than it needs to be.  But I got wife approval and will probably only ever get to build one of these given the limited space we currently have.  So I’m going for an aircraft carrier on steroids, the swiss army knife of arcade cabinets.
My unique requirements:
1.Converts from an arcade to a standup desk
-I know this may drive some of the traditionalist nuts, but I don’t have a lot of space ended up building an awesome PC I want to use for both arcade and PC gaming.  I currently have 2 screens I want to use but am thinking about running 3.
2.A removable control panel that serves as a standalone Raspberry Pi arcade.
-I don’t want to be limited to playing at my home. I want to be able to bring it with me to friends’ homes.
3.Some sort of built-in media component
-Yes, I know, I know… It’s a lot but I want to be able to run movies / streaming through the arcade. Again, I don’t have a lot of space… So I’m going for a man cave in a box.
My not so unique requirements:
4 player set up w/ trackball, spinner and light gun compatibility.
8 buttons for player 1 and 2
4 buttons for player 3 and 4
Ability to play just about anything out there.
Lots of LEDS (I’m hooked on lighting, it’s like a grateful dead laser show over here).
4 player coin drawer
LED Marquee
kickplate
My current hardware list:
2x 4/8 Servo Sticks
2x  Servo Stick LEDS
2x I-Pac Ultimate I/O’s
24x - Industrias Lorenzo Translucent with Black Concave Plunger –
13x  Industrias Lorenzo Convex Translucent Short Stem Pushbutton
A ton of 75 Gram Cherry Microswitchs
All the IL-lumination RGB 5VDC LEDs
1x ELEWIND 30mm push button switch With POWER symbol With 6*15cm wires(PM301F-11E/B/12V/S With POWER symbol with 6*15cm wires)
1x 22mm mounting diameter metal USB3.0 Female A change to Female A (Black surface)
1x 25mm metal USB connector/USB socket 2x USB3.0 FEMALE A - FEMALE A
1x 22mm mounting diameter HDMI connector USB Female to Female
1x Arcade Computer Cabinet Switched Power Socket Connector AC 250V Lighting with Fuse Holder for Jamma and Mame DIY Game Machine
2x  4/8 Way Adjustable Joystick Arcade Joystick DIY Joystick Fighting Stick Parts for Game Video Arcade Very Rugged Construction Red
22mm mounting diameter metal 2x USB2.0 FEMALE A - MALE A 2x60cm wiring
1x Raspberry Pi 3b+
1x Raspberry Pi Touchscreen
1X USB hub
1X USB charging hub
1x Alexa Enabled Power Strip
Corsair fan and Controller Commander Pro
1x NZXT Internal USB Hub - Expands 5 USB 2.0 Ports - Sleek Multifunctional Design - Molex Connection - Plug and Play
      UGREEN USB to SATA USB 3.0 to Hard Drive Adapter Cable Converter for 2.5 3.5 Inch Hard Drive Disk HDD and SSD Support UASP SATA III with 12V 2A
        Power Adapter
1x Pimoroni OnOff SHIM
1x OontZ Angle 3 Enhanced Stereo Edition IPX5 Splashproof Portable Bluetooth Speaker with Volume Booster AMP 10 Watts Power, Custom Bass Radiator, 100'
        Wireless Range Bluetooth 4.2
And just about every type of usb chord
As well as all the internal switch wiring etc…
On pre-order:
1x Sinden Lightgun w/ recoil
PC:
Running a custom built PC (Won’t get into the specs here but it can run just about anything)
Current Software:
Launchbox w/ Bigbox on the pc
Currently running Noobs with Lakka on the PI (still trying to figure out what works best here)
Woodwork:
1 sheet ¾ inch birch plywood
A bunch of clear coat epoxy resign
A ton of screws and wood glue
1 Piano Hinge
More Velcro then a 5yr old’s shoe closet in the 80s.
Lots of sandpaper, paint and wood stain.
Where I am in the process:
Will try to update this and the list of hardware etc… as I progress.
Control panel is 90% done, need to figure out the Pi software and decide how much effort I want to put into cleaning up the wiring.
Next step: Figure out how the heck I’m going to build the cabinet I want.
« Last Edit: June 15, 2019, 02:42:00 pm by TheDistrict »
Re: ClappCade - The ridiculous and inefficient newbie build
« Reply #1 on: June 09, 2019, 07:34:37 pm »
Well, this will be interesting at least! I'm subscribed.  :burgerking:
« Reply #2 on: June 09, 2019, 10:55:29 pm »
Build what you want, but can you, like, stop disparaging “traditionalists” and just let your project stand on its own. Why turn off people for no reason?
  • Bitches love Centipede
« Reply #3 on: June 09, 2019, 11:29:35 pm »
After a ton of research...
...not enough.
%Bartop
TheDistrict
« Reply #4 on: June 10, 2019, 02:02:13 am »
Hi Yotsuya,
Not trying to disparage anyone. Just wanted to put it out there so as to avoid the argument before it starts. I love the traditional builds but I see a lot of arguments in these forums (not  here per say) across the web about being true to old specs etc... I just want to let people know up front that this is probably not going to be that.  I actually hope to eventually make a more traditional cabinet when I have the space.
Laythe
  • Last login:February 18, 2026, 06:54:56 pm
« Reply #5 on: June 10, 2019, 03:53:45 am »
I'm glad to see somebody building their own.
It's not what I'd build, but if it's what you'd build?  Go for it.   :applaud:
I would like to warn you it's not going to play everything out there, though.  You don't have 4 spinners for Warlords, 2 trackballs for Marble Madness, a 270 wheel for Outrun, an analog flight stick and throttle for Afterburner, a yoke for Stun Runner and Star Wars, or a push-pull spinner for Discs of Tron.  Saying "everything" doesn't really free you from having to make some tough choices about your game list.  I say this not to be a pain - I say it hoping to steer your expectations a little.  Even with your staggeringly large control panel spec, you're still leaving quite a few games out.  Leaving games out is OK!
I'm curious to see how you manage the PC-but-also-a-Pi mobile function.
Jimbo
    • Wood Finishes Direct
« Reply #6 on: June 10, 2019, 04:25:53 am »
Wow... that's a lot of work...  Normally when I start a project, it ends up taking 3 times a long as I thought it would.  Just sayin'   ;D
Have you got any photos of the work you've done on the CP already?
I'd recommend sketchup for designing the cabinet.
Titchgamer
« Reply #7 on: June 10, 2019, 05:51:40 am »
Well this should be interesting.
Pi and PC standup to Desk.
I am genuinely intrigued!
  • Last login:Today at 11:05:02 am
« Reply #8 on: June 10, 2019, 06:54:36 am »
Here is what I’m thinking in terms of my build.  (Again, I’m new so please let me know if this will never work):
This will never work well. You are trying to do too much. People try this all of the time and it always ends badly.
If you don't have space then just build the portable CP.
Trying to get all of that software and hardware to work together is a recipe for disaster.
Every single comment made before mine is telling you not to do this. They just aren't coming out and saying it directly.
« Reply #9 on: June 10, 2019, 08:52:56 am »
My best advice to what you are trying to achieve - made a pedestal. Build a control panel and a base for it to go on. House a pc in the base and have the control panel latch on at plug in via usb.
Separately, build a little pi box and have your control panel plug into that as well. Since it seems you are set on having LEDs everywhere, you will probably want the box to have a secondary power source as well.
This way you won't have to worry about a media component as well. Watch movies on the same screen, but just use another input.
Of course, this is separate from the feedback that I am not going to drill in saying this project as listed is destined to fail. I would say start small and scale up. I also really have a hard time seeing anyone bringing a battleship sized control panel to a friend's house. Besides, part of the lure of an arcade machine is it makes your house the destination.
Anyway. Good luck. Sink or swim, I will watch with interest.  ;)
« Reply #10 on: June 10, 2019, 09:15:59 am »
Hi Yotsuya,
Sure thing. I proudly consider myself a purist and prefer seeing classic lines and such, but I also love creativity and innovation (see Laythe’s builds). So I would never discourage it, so long as it’s not a disaster in the making or repeating tried and true design mistakes (or possibly a way to kill fish).
Just plan it out, build what you want, and stop telling people like me they aren’t going to like it. I’d rather be pleasantly surprised than predisposed to not liking something because the builder keeps telling me I’m not going to. ;)
Gilrock
« Reply #11 on: June 10, 2019, 09:26:01 am »
I don't know a newbie building an aircraft carrier panel based on Flynn's Arcade is becoming a tradition.  At ZapCon that was the big joke when we sat around talking about the forum.
« Reply #12 on: June 10, 2019, 09:32:07 am »
I think a lot of them do so because it’s very well documented and plans are available. They want something that will play games and let them use that 42” TV that’s gathering dust and so this is a good starting point for them.
TheDistrict
« Reply #13 on: June 10, 2019, 12:18:23 pm »
Hi Yotsuya,
All really great points. I will change the language in the post.  The traditionalists are why all is newbies got into this in the first place.  Thanks for the input.
« Reply #14 on: June 10, 2019, 12:46:52 pm »
Hi Yotsuya,
No problem! Looking forward to seeing what you end up with.
  • Last login:Yesterday at 12:10:15 pm
« Reply #15 on: June 10, 2019, 03:44:50 pm »
I can't wait to see this thing - it sounds ambitious for sure.
TheDistrict
« Reply #16 on: June 15, 2019, 02:54:18 pm »
sorry for the delay but you know work... now that it’s the weekend.  Here are a couple of photos of the control panel as it stands today.
View from the top:
View from the front:
Power button powers the Pi and the additional button I use to exit Bigbox menus.  On the far right is a USB 3 input. Loads into the pi or pc through the usb hub.
View of the back:
4 usb inputs. One master for PC (feeds into the usb switch to toggle between pc and pi) The rest feed into the hub.  Also one hdmi out for the pi (makes the system portable and viewable on a tv).
View of the hot mess that is inside the control panel:
This is still a work in progress I have been tinkering with the wiring but hope to clean it up soon.
Next step is to start planning the cabinet.  The pi is functional and works as a stand alone unit (not shown the guitar start and hooks I use to strap it over my shoulder and carry it) The panel also works great with bigbox via usb out and the switch between the two just a push of a button.
 So now it’s just time to figure out what’s going to house it.
« Reply #17 on: June 15, 2019, 03:51:52 pm »
You might want to stick a thermometer in there just to be safe. Those wall warts are not going to be very happy in that enclosed space.
TheDistrict
« Reply #18 on: June 15, 2019, 04:07:29 pm »
Thanks for the tip!  It's hard to see in the photo but I have a Corsair commander pro hooked up and attached to the hub.  It's got 3 temperature gauges and gives me an output on the PC. Also adjusts the fan in the button depending on temp.  So far so good.  But still keeping an eye on it.
« Reply #19 on: June 15, 2019, 04:09:10 pm »
That is a good precaution. My Spidey sense is tingling like crazy looking at that interior.
« Last Edit: June 15, 2019, 08:33:17 pm by Mike A »
TheDistrict
« Reply #20 on: June 15, 2019, 05:35:35 pm »
This is a great point.  I guess I should say as much as possible.  The one here that I didn't think about was marble madness.  That is definitely a game I enjoy. I can still play one player though correct?
Laythe
« Reply #21 on: June 15, 2019, 05:42:38 pm »
Yep, one trackball will do 1p marble madness.
rablack97
« Reply #22 on: June 16, 2019, 12:49:56 pm »
what's little screen for?
TheDistrict
« Reply #23 on: June 16, 2019, 05:23:40 pm »
It a raspberry pi touch screen. Allows me to get set up before going out to hdmi.
TheDistrict
« Reply #24 on: July 21, 2019, 03:02:13 pm »
Ok it has been a while and this summer has been crazy but I wanted to post what little progress I have been able to get done! The last month has been spent trying to figure out how to build the cabinet in a way that fits in the limited space I have in my office.
Figuring out how to 3D model something that we can CNC and then build to work as
1. An arcade cabinet and
2. A standing desk.
Since I have Zero experience in CAD but over 15 years of experience managing offshore teams I decided to outsource the idea on Fiverr  (I know, I know). It took a little extra time but I think we may have worked it out (will know more when I get the pieces back from the CNC shop next week).
After some back and forth we decided that using linear actuators to lower and lift a platform that the control panel sits on may be the best option.  The thought being you can lower the CP pull out a drawer and unfold it over the top of the CP then move the CP back up to make it flush.  Thus creating a flat surface that covers the joysticks buttons etc… that can be used as a stand up desk.  See the attached PDF for our initial mockup.
You can also see from the attached images that since I went through the trouble of getting everything done in 3d I decided to have the control panel redone as well.  The initial one was a little off on measurement and after playing with it for a bit I think the screen is better suited on the left of the CP (near P1).  Next up is assembling the pieces when I get them back and trying to figure out how to wire the new CP in a WAY cleaner way (would love tips here). I'm also working an LED Matrix Marquee which may not happen given it looks like I might have to learn python to get something up and running (anyone do a Pi LED Matrix Marquee? I would love tips).     Thank you again all for following along and the tips!
TheDistrict
« Reply #25 on: July 21, 2019, 03:06:43 pm »
Looks like the PDF of the mock-up didn't post so here it is as JPG's
MiteWiseacre
  • Last login:May 24, 2025, 03:52:24 pm
« Reply #26 on: July 21, 2019, 04:06:45 pm »
You really want to hide the controls, eh?
I’m impressed by the lengths you’re going
« Reply #27 on: July 21, 2019, 04:56:44 pm »
*Aircraft Carrier
%Bartop
Titchgamer
« Reply #29 on: July 22, 2019, 02:45:35 pm »
So you are building a standing desk and arcade cabinet as one unit?
TheDistrict
« Reply #30 on: July 22, 2019, 06:40:57 pm »
That is the plan! It will convert back and forth.
gingecko
  • I'm working on it!
« Reply #31 on: July 24, 2019, 04:51:16 pm »
Ok, I gotta watch this.
