Author Topic: Hantarex polo problem (SOLVED)  (Read 1770 times)
Justez
  • Last login:January 11, 2026, 03:19:00 am
« on: June 07, 2019, 02:40:33 am »
SOLVED: green colur IC transistor  faulty in socket board,
Hi.
I have a hantarex polo 25, the problem is that when I turn it on cold, for the first ten minutes I have green flashes and interference in the video, and a small buzz in the chassis.
After about ten minutes, it works correctly again.
I attach a video of the problem.
« Last Edit: July 08, 2019, 07:04:03 am by Justez »
perjmolsen
  • Last login:December 08, 2022, 04:09:06 am
  • I want to learn, and try.. I NEWER give up :)
    • My gameroom
Re: Hantarex polo problem
« Reply #1 on: July 01, 2019, 08:48:44 am »
Hi
My best guess is that a cap is bad...
When did it last have had a cap kit?
Try to check the solder points at the neck board around the color transistors (try to swap the red and green color transistor, to rule out the transistor, if the problem follow the transistor)
Check also the cap C2
Justez
Re: Hantarex polo problem (SOLVED)
« Reply #2 on: July 08, 2019, 07:05:59 am »
finally was green colour faulty transistor in socket board, thanx!!!
perjmolsen
    • My gameroom
« Reply #3 on: July 09, 2019, 07:40:08 am »
Super  :cheers:
