Author Topic: Can't read list in Mamewah  (Read 1025 times)
crapjoint
  • Last login:November 07, 2007, 08:14:20 pm
« on: February 12, 2004, 05:19:08 pm »
Trying to get my cab set up and I have Windows and stuff working on it, it's clear with 640X288 Res.  I changed Mamewah to this setting also.  Problem is, in Mamewah, I can't read the list, it's all fuzzy.  Games play fine.  Help??
crapjoint
Re:Can't read list in Mamewah
« Reply #1 on: February 14, 2004, 04:28:01 pm »
Noone can help?
TalkingOctopus
  • Last login:August 04, 2025, 03:48:02 am
    • My Arcade
« Reply #2 on: February 15, 2004, 01:14:37 am »
Have you tried using the layout editor to increase the font size of the list?  I use 26 point font for mine.
Minwah
    • MAMEWAH
« Reply #3 on: February 15, 2004, 11:05:56 am »
Did you download the layouts from my site?  If you just set the layout without actually having the required file/folder structure then it will default to 640x480...I would think you should be able to see it OK if that were the case tho, it would just be a bit flickery.
PS This should be in the Software Forum
