Author Topic: CRT Emudriver Hell  (Read 35433 times)
  • Last login:Yesterday at 04:02:37 pm
Re: CRT Emudriver Hell
« Reply #80 on: May 30, 2019, 11:13:52 am »
Do you get the same listing there when the you select the other options in the upper menu "Device:"? E.g. if you pick \\.\DISPLAY21 in there.
FrizzleFried
    • Idaho Garagecade
« Reply #81 on: May 30, 2019, 11:15:15 am »
Correct.
« Reply #82 on: May 30, 2019, 11:22:27 am »
Thanks so much.
Inside VMMaker's folder, you're going to find a file named edid.bin. Could you please zip it and attach it here?
« Reply #83 on: May 30, 2019, 11:32:09 am »
I've just compiled a verbose version of VMMaker, please run it in your system and post the log here, I've attached the executable, just rename the old one and drop this one in the same folder. I just need a copy of its startup log, no need to test anything else.
I really appreciate your collaboration.
EDIT: Just to add the actual complete log we need requires you to enter the Edit Settings tab.
Mine looks like this:
Getting driver information for \\.\DISPLAY1
ADL Library found, retrieving functions...
adapter(0).mindex 0
adapter(0).mbus 11
adapter(0).mname Radeon RX Vega (CRT Emudriver)
adapter(0).mdisplayname \\.\DISPLAY1
adapter(0).mnumofdisplays 30
adapter(1).mindex 1
adapter(1).mbus 11
adapter(1).mname Radeon RX Vega (CRT Emudriver)
adapter(1).mdisplayname \\.\DISPLAY2
adapter(1).mnumofdisplays 30
adapter(2).mindex 2
adapter(2).mbus 11
adapter(2).mname Radeon RX Vega (CRT Emudriver)
adapter(2).mdisplayname \\.\DISPLAY3
adapter(2).mnumofdisplays 30
adapter(3).mindex 3
adapter(3).mbus 11
adapter(3).mname Radeon RX Vega (CRT Emudriver)
adapter(3).mdisplayname \\.\DISPLAY4
adapter(3).mnumofdisplays 30
adapter(4).mindex 4
adapter(4).mbus 11
adapter(4).mname Radeon RX Vega (CRT Emudriver)
adapter(4).mdisplayname \\.\DISPLAY5
adapter(4).mnumofdisplays 30
adapter(5).mindex 5
adapter(5).mbus 11
adapter(5).mname Radeon RX Vega (CRT Emudriver)
adapter(5).mdisplayname \\.\DISPLAY6
adapter(5).mnumofdisplays 30
adapter(6).mindex 6
adapter(6).mbus 11
adapter(6).mname Radeon RX Vega (CRT Emudriver)
adapter(6).mdisplayname \\.\DISPLAY7
adapter(6).mnumofdisplays 30
adapter(7).mindex 7
adapter(7).mbus 11
adapter(7).mname Radeon RX Vega (CRT Emudriver)
adapter(7).mdisplayname \\.\DISPLAY8
adapter(7).mnumofdisplays 30
adapter(8).mindex 8
adapter(8).mbus 11
adapter(8).mname Radeon RX Vega (CRT Emudriver)
adapter(8).mdisplayname \\.\DISPLAY9
adapter(8).mnumofdisplays 30
adapter(9).mindex 9
adapter(9).mbus 11
adapter(9).mname Radeon RX Vega (CRT Emudriver)
adapter(9).mdisplayname \\.\DISPLAY10
adapter(9).mnumofdisplays 30
adapter(10).mindex 10
adapter(10).mbus 11
adapter(10).mname Radeon RX Vega (CRT Emudriver)
adapter(10).mdisplayname \\.\DISPLAY11
adapter(10).mnumofdisplays 30
adapter(11).mindex 11
adapter(11).mbus 11
adapter(11).mname Radeon RX Vega (CRT Emudriver)
adapter(11).mdisplayname \\.\DISPLAY12
adapter(11).mnumofdisplays 30
adapter(12).mindex 12
adapter(12).mbus 11
adapter(12).mname Radeon RX Vega (CRT Emudriver)
adapter(12).mdisplayname \\.\DISPLAY13
adapter(12).mnumofdisplays 30
adapter(13).mindex 13
adapter(13).mbus 11
adapter(13).mname Radeon RX Vega (CRT Emudriver)
adapter(13).mdisplayname \\.\DISPLAY14
adapter(13).mnumofdisplays 30
adapter(14).mindex 14
adapter(14).mbus 11
adapter(14).mname Radeon RX Vega (CRT Emudriver)
adapter(14).mdisplayname \\.\DISPLAY15
adapter(14).mnumofdisplays 30
adapter(15).mindex 15
adapter(15).mbus 11
adapter(15).mname Radeon RX Vega (CRT Emudriver)
adapter(15).mdisplayname \\.\DISPLAY16
adapter(15).mnumofdisplays 30
Connector 3 HDMI-A
Connector 0 DisplayPort
Connector 1 DisplayPort
Connector 2 DisplayPort
ADL functions retrieved successfully.
CRT Emudriver 2.0 (18.5) found.
logical_adapter_index: 0 logical_index: 0 physical_index:  0 display_connector: 15
logical_adapter_index: -1 logical_index: 4 physical_index:  4 display_connector: 15
logical_adapter_index: -1 logical_index: 8 physical_index:  8 display_connector: 15
logical_adapter_index: -1 logical_index: 1 physical_index:  1 display_connector: 15
logical_adapter_index: -1 logical_index: 2 physical_index:  2 display_connector: 15
logical_adapter_index: -1 logical_index: 3 physical_index:  3 display_connector: 15
logical_adapter_index: -1 logical_index: 5 physical_index:  5 display_connector: 15
logical_adapter_index: -1 logical_index: 6 physical_index:  6 display_connector: 15
logical_adapter_index: -1 logical_index: 7 physical_index:  7 display_connector: 15
logical_adapter_index: -1 logical_index: 9 physical_index:  9 display_connector: 15
logical_adapter_index: -1 logical_index: 10 physical_index: 10 display_connector: 15
logical_adapter_index: -1 logical_index: 11 physical_index: 11 display_connector: 15
logical_adapter_index: 1 logical_index: 12 physical_index: 12 display_connector: 10
logical_adapter_index: -1 logical_index: 13 physical_index: 13 display_connector: 17
logical_adapter_index: -1 logical_index: 14 physical_index: 14 display_connector: 15
logical_adapter_index: -1 logical_index: 15 physical_index: 15 display_connector: 15
logical_adapter_index: -1 logical_index: 16 physical_index: 16 display_connector: 15
logical_adapter_index: -1 logical_index: 17 physical_index: 17 display_connector: 15
logical_adapter_index: -1 logical_index: 18 physical_index: 18 display_connector: 15
logical_adapter_index: -1 logical_index: 19 physical_index: 19 display_connector: 15
logical_adapter_index: -1 logical_index: 20 physical_index: 20 display_connector: 15
logical_adapter_index: -1 logical_index: 21 physical_index: 21 display_connector: 15
logical_adapter_index: -1 logical_index: 22 physical_index: 22 display_connector: 15
logical_adapter_index: -1 logical_index: 23 physical_index: 23 display_connector: 15
logical_adapter_index: -1 logical_index: 24 physical_index: 24 display_connector: 15
logical_adapter_index: -1 logical_index: 25 physical_index: 25 display_connector: 15
logical_adapter_index: -1 logical_index: 26 physical_index: 26 display_connector: 15
logical_adapter_index: -1 logical_index: 27 physical_index: 27 display_connector: 15
logical_adapter_index: -1 logical_index: 28 physical_index: 28 display_connector: 15
logical_adapter_index: -1 logical_index: 29 physical_index: 29 display_connector: 15
« Last Edit: May 30, 2019, 11:42:07 am by Calamity »
FrizzleFried
    • Idaho Garagecade
« Reply #84 on: May 30, 2019, 11:43:16 am »
Thanks so much.
Attached...
« Reply #85 on: May 30, 2019, 11:48:17 am »
Thanks! Also, just in case, try using the Arcade_15 preset instead of the K7000 one.
FrizzleFried
    • Idaho Garagecade
« Reply #86 on: May 30, 2019, 11:50:22 am »
Is this what you are looking for?
  _____ _____ _____     _
 |  |  |     |     |___| |_ ___ ___
 |  |  | | | | | | | .'| '_| -_|  _|
  \___/|_|_|_|_|_|_|__,|_,_|___|_|   2.0 beta 15 by Calamity - 2008/2019
Processing config...
Exporting settings to mame.ini...
>>display init \System\CurrentControlSet\Control\Video\{D39178CA-82E6-11E9-8904-99523214DC8F}\0001
Listing display devices...
\\.\DISPLAY31 - AMD Radeon(TM) Vega 8 Graphics - HP vp17 - enabled - HKLM\System\CurrentControlSet\Control\Video\{D39178CA-82E6-11E9-8904-99523214DC8F}\0000
\\.\DISPLAY32 - AMD Radeon(TM) Vega 8 Graphics - Generic PnP Monitor - enabled - HKLM\System\CurrentControlSet\Control\Video\{D39178CA-82E6-11E9-8904-99523214DC8F}\0001
\\.\DISPLAY33 - AMD Radeon(TM) Vega 8 Graphics - No monitor - disabled - HKLM\System\CurrentControlSet\Control\Video\{D39178CA-82E6-11E9-8904-99523214DC8F}\0002
\\.\DISPLAY34 - AMD Radeon(TM) Vega 8 Graphics - No monitor - disabled - HKLM\System\CurrentControlSet\Control\Video\{D39178CA-82E6-11E9-8904-99523214DC8F}\0003
Getting driver information for \\.\DISPLAY32
adapter(0).mindex 0
adapter(0).mbus 7
adapter(0).mname AMD Radeon(TM) Vega 8 Graphics (CRT Emudriver)
adapter(0).mdisplayname \\.\DISPLAY31
adapter(0).mnumofdisplays 6
adapter(1).mindex 1
adapter(1).mbus 7
adapter(1).mname AMD Radeon(TM) Vega 8 Graphics (CRT Emudriver)
adapter(1).mdisplayname \\.\DISPLAY32
adapter(1).mnumofdisplays 6
adapter(2).mindex 2
adapter(2).mbus 7
adapter(2).mname AMD Radeon(TM) Vega 8 Graphics (CRT Emudriver)
adapter(2).mdisplayname \\.\DISPLAY33
adapter(2).mnumofdisplays 6
adapter(3).mindex 3
adapter(3).mbus 7
adapter(3).mname AMD Radeon(TM) Vega 8 Graphics (CRT Emudriver)
adapter(3).mdisplayname \\.\DISPLAY34
adapter(3).mnumofdisplays 6
logical_adapter_index: 1 logical_index: 4 physical_index:  4 display_connector: 10
logical_adapter_index: -1 logical_index: 5 physical_index:  5 display_connector: 2
>>config
>>modelist build
Creating mode list...
Importing video modes from custom list...
   31 video modes found
Generating dynamic mode table...
 16 redundant video modes found.
Reducing mode list...
 0 video modes dropped.
 15 modelines generated.
"640x480_60 15.69KHz 60.00Hz" 13.05 640 664 728 832 480 483 488 523 interlace -hsync -vsync
"2560x240_60 15.66KHz 60.00Hz" 52.12 2560 2664 2912 3328 240 242 245 261 -hsync -vsync
"2560x248_59 15.80KHz 58.96Hz" 52.71 2560 2664 2912 3336 248 249 252 268 -hsync -vsync
"2560x256_57 15.80KHz 57.25Hz" 52.71 2560 2664 2912 3336 256 257 260 276 -hsync -vsync
"2560x264_56 15.80KHz 55.63Hz" 52.71 2560 2664 2912 3336 264 265 268 284 -hsync -vsync
"2560x272_54 15.80KHz 54.11Hz" 52.71 2560 2664 2912 3336 272 273 276 292 -hsync -vsync
"2560x280_53 15.80KHz 52.67Hz" 52.71 2560 2664 2912 3336 280 281 284 300 -hsync -vsync
"2560x288_51 15.80KHz 51.30Hz" 52.71 2560 2664 2912 3336 288 289 292 308 -hsync -vsync
"2560x448_60 15.69KHz 60.00Hz" 52.22 2560 2664 2912 3328 448 467 472 523 interlace -hsync -vsync
"2560x464_60 15.69KHz 60.00Hz" 52.22 2560 2664 2912 3328 464 475 480 523 interlace -hsync -vsync
"2560x480_60 15.69KHz 60.00Hz" 52.22 2560 2664 2912 3328 480 483 488 523 interlace -hsync -vsync
"2560x496_59 15.83KHz 58.96Hz" 52.81 2560 2664 2912 3336 496 498 503 537 interlace -hsync -vsync
"2560x512_57 15.83KHz 57.25Hz" 52.80 2560 2664 2912 3336 512 514 519 553 interlace -hsync -vsync
"2560x544_54 15.83KHz 54.11Hz" 52.80 2560 2664 2912 3336 544 546 551 585 interlace -hsync -vsync
"2560x560_53 15.83KHz 52.67Hz" 52.80 2560 2664 2912 3336 560 562 567 601 interlace -hsync -vsync
>>modelist install
Installing modelines in system...
Mode "640x480_60 15.69KHz 60.00Hz" rejected by driver.
Mode "2560x448_60 15.69KHz 60.00Hz" rejected by driver.
Mode "2560x464_60 15.69KHz 60.00Hz" rejected by driver.
Mode "2560x480_60 15.69KHz 60.00Hz" rejected by driver.
Mode "2560x496_59 15.83KHz 58.96Hz" rejected by driver.
Mode "2560x512_57 15.83KHz 57.25Hz" rejected by driver.
Mode "2560x544_54 15.83KHz 54.11Hz" rejected by driver.
Mode "2560x560_53 15.83KHz 52.67Hz" rejected by driver.
15 modelines installed.
« Reply #87 on: May 30, 2019, 11:50:47 am »
Yes!
FrizzleFried
    • Idaho Garagecade
« Reply #88 on: May 30, 2019, 11:51:24 am »
Redoing with ARCADE_15 settings...
FrizzleFried
    • Idaho Garagecade
« Reply #89 on: May 30, 2019, 11:52:47 am »
  _____ _____ _____     _
adapter(0).mindex 0
adapter(0).mbus 7
adapter(1).mindex 1
adapter(1).mbus 7
adapter(2).mindex 2
adapter(2).mbus 7
adapter(3).mindex 3
adapter(3).mbus 7
>>config
>>modelist build
"640x480_60 15.69KHz 60.00Hz" 13.05 640 664 728 832 480 483 489 523 interlace -hsync -vsync
"2560x248_60 16.14KHz 60.00Hz" 54.23 2560 2672 2928 3360 248 250 253 269 -hsync -vsync
"2560x256_58 16.20KHz 58.48Hz" 54.43 2560 2672 2928 3360 256 258 261 277 -hsync -vsync
"2560x264_57 16.20KHz 56.84Hz" 54.43 2560 2672 2928 3360 264 266 269 285 -hsync -vsync
"2560x272_55 16.20KHz 55.29Hz" 54.43 2560 2672 2928 3360 272 274 277 293 -hsync -vsync
"2560x280_54 16.20KHz 53.82Hz" 54.43 2560 2672 2928 3360 280 282 285 301 -hsync -vsync
"2560x288_52 16.20KHz 52.43Hz" 54.43 2560 2672 2928 3360 288 290 293 309 -hsync -vsync
"2560x448_60 15.69KHz 60.00Hz" 52.22 2560 2664 2912 3328 448 467 473 523 interlace -hsync -vsync
"2560x464_60 15.69KHz 60.00Hz" 52.22 2560 2664 2912 3328 464 475 481 523 interlace -hsync -vsync
"2560x480_60 15.69KHz 60.00Hz" 52.22 2560 2664 2912 3328 480 483 489 523 interlace -hsync -vsync
"2560x496_60 16.17KHz 60.00Hz" 54.33 2560 2672 2928 3360 496 499 505 539 interlace -hsync -vsync
"2560x512_58 16.23KHz 58.48Hz" 54.66 2560 2672 2928 3368 512 515 521 555 interlace -hsync -vsync
"2560x544_55 16.23KHz 55.29Hz" 54.65 2560 2672 2928 3368 544 547 553 587 interlace -hsync -vsync
"2560x560_54 16.23KHz 53.82Hz" 54.65 2560 2672 2928 3368 560 563 569 603 interlace -hsync -vsync
>>modelist install
Mode "2560x496_60 16.17KHz 60.00Hz" rejected by driver.
Mode "2560x512_58 16.23KHz 58.48Hz" rejected by driver.
Mode "2560x544_55 16.23KHz 55.29Hz" rejected by driver.
Mode "2560x560_54 16.23KHz 53.82Hz" rejected by driver.
« Reply #90 on: May 30, 2019, 12:17:19 pm »
One final test for me, please. Could you try enabling EDID emulation with the ARCADE_31 preset?
FrizzleFried
    • Idaho Garagecade
« Reply #91 on: May 30, 2019, 12:25:00 pm »
Doing so now (trying to do all this between actual "work")...
« Reply #92 on: May 30, 2019, 12:25:58 pm »
Me too  ;)
EDIT: Just need to see if the driver eats the EDID. Of course it won't be valid for 15 kHz so don't even try installing modes.
FrizzleFried
    • Idaho Garagecade
« Reply #93 on: May 30, 2019, 12:30:00 pm »
Me too  ;)
  _____ _____ _____     _
\\.\DISPLAY46 - AMD Radeon(TM) Vega 8 Graphics - HP vp17 - enabled - HKLM\System\CurrentControlSet\Control\Video\{D39178CA-82E6-11E9-8904-99523214DC8F}\0000
\\.\DISPLAY47 - AMD Radeon(TM) Vega 8 Graphics - Generic PnP Monitor - enabled - HKLM\System\CurrentControlSet\Control\Video\{D39178CA-82E6-11E9-8904-99523214DC8F}\0001
\\.\DISPLAY48 - AMD Radeon(TM) Vega 8 Graphics - No monitor - disabled - HKLM\System\CurrentControlSet\Control\Video\{D39178CA-82E6-11E9-8904-99523214DC8F}\0002
\\.\DISPLAY49 - AMD Radeon(TM) Vega 8 Graphics - No monitor - disabled - HKLM\System\CurrentControlSet\Control\Video\{D39178CA-82E6-11E9-8904-99523214DC8F}\0003
Getting driver information for \\.\DISPLAY47
adapter(0).mindex 0
adapter(0).mbus 7
adapter(0).mdisplayname \\.\DISPLAY46
adapter(1).mindex 1
adapter(1).mbus 7
adapter(1).mdisplayname \\.\DISPLAY47
adapter(2).mindex 2
adapter(2).mbus 7
adapter(2).mdisplayname \\.\DISPLAY48
adapter(3).mindex 3
adapter(3).mbus 7
adapter(3).mdisplayname \\.\DISPLAY49
>>edid start Digital_4
Restarting device \\.\DISPLAY47
D:\UTILITIES\crt_emudriver_&_tools_2.0_beta_15_18.5.1_W.10-64\devutil64.exe reset "PCI\VEN_1002&DEV_15DD&SUBSYS_D0001458&REV_C8"
Device has changed.
\\.\DISPLAY51 - AMD Radeon(TM) Vega 8 Graphics - HP vp17 - enabled - HKLM\System\CurrentControlSet\Control\Video\{D39178CA-82E6-11E9-8904-99523214DC8F}\0000
\\.\DISPLAY52 - AMD Radeon(TM) Vega 8 Graphics - Generic PnP Monitor - enabled - HKLM\System\CurrentControlSet\Control\Video\{D39178CA-82E6-11E9-8904-99523214DC8F}\0001
\\.\DISPLAY53 - AMD Radeon(TM) Vega 8 Graphics - No monitor - disabled - HKLM\System\CurrentControlSet\Control\Video\{D39178CA-82E6-11E9-8904-99523214DC8F}\0002
\\.\DISPLAY54 - AMD Radeon(TM) Vega 8 Graphics - No monitor - disabled - HKLM\System\CurrentControlSet\Control\Video\{D39178CA-82E6-11E9-8904-99523214DC8F}\0003
enabling \\.\DISPLAY52 : success
Getting driver information for \\.\DISPLAY52
adapter(0).mindex 0
adapter(0).mbus 7
adapter(0).mdisplayname \\.\DISPLAY51
adapter(1).mindex 1
adapter(1).mbus 7
adapter(1).mdisplayname \\.\DISPLAY52
adapter(2).mindex 2
adapter(2).mbus 7
adapter(2).mdisplayname \\.\DISPLAY53
adapter(3).mindex 3
adapter(3).mbus 7
adapter(3).mdisplayname \\.\DISPLAY54
>>config
>>modelist build
 10 redundant video modes found.
 21 modelines generated.
"640x480_60 31.50KHz 60.00Hz" 25.45 640 664 760 808 480 491 493 525 -hsync -vsync
"2560x384_60 31.44KHz 60.00Hz" 101.61 2560 2656 3040 3232 384 443 445 524 -hsync -vsync
"2560x392_60 31.44KHz 60.00Hz" 101.61 2560 2656 3040 3232 392 447 449 524 -hsync -vsync
"2560x400_60 31.44KHz 60.00Hz" 101.61 2560 2656 3040 3232 400 451 453 524 -hsync -vsync
"2560x416_60 31.44KHz 60.00Hz" 101.61 2560 2656 3040 3232 416 459 461 524 -hsync -vsync
"2560x432_60 31.44KHz 60.00Hz" 101.61 2560 2656 3040 3232 432 467 469 524 -hsync -vsync
"2560x448_60 31.44KHz 60.00Hz" 101.61 2560 2656 3040 3232 448 475 477 524 -hsync -vsync
"2560x464_60 31.44KHz 60.00Hz" 101.61 2560 2656 3040 3232 464 483 485 524 -hsync -vsync
"2560x480_60 31.50KHz 60.00Hz" 101.81 2560 2656 3040 3232 480 491 493 525 -hsync -vsync
"2560x768_60 31.47KHz 60.00Hz" 101.71 2560 2656 3040 3232 768 885 889 1049 interlace -hsync -vsync
"2560x800_60 31.47KHz 60.00Hz" 101.71 2560 2656 3040 3232 800 901 905 1049 interlace -hsync -vsync
"2560x960_60 31.53KHz 60.00Hz" 101.90 2560 2656 3040 3232 960 982 986 1051 interlace -hsync -vsync
"5120x480_60 31.50KHz 60.00Hz" 203.62 5120 5312 6080 6464 480 491 493 525 -hsync -vsync
"7680x768_60 31.47KHz 60.00Hz" 305.13 7680 7968 9120 9696 768 885 889 1049 interlace -hsync -vsync
"7680x792_60 31.47KHz 60.00Hz" 305.13 7680 7968 9120 9696 792 897 901 1049 interlace -hsync -vsync
"7680x816_60 31.47KHz 60.00Hz" 305.13 7680 7968 9120 9696 816 909 913 1049 interlace -hsync -vsync
"7680x840_60 31.47KHz 60.00Hz" 305.13 7680 7968 9120 9696 840 921 925 1049 interlace -hsync -vsync
"7680x864_60 31.47KHz 60.00Hz" 305.13 7680 7968 9120 9696 864 933 937 1049 interlace -hsync -vsync
"7680x888_60 31.47KHz 60.00Hz" 305.13 7680 7968 9120 9696 888 945 949 1049 interlace -hsync -vsync
"7680x912_60 31.47KHz 60.00Hz" 305.13 7680 7968 9120 9696 912 957 961 1049 interlace -hsync -vsync
"7680x960_60 31.53KHz 60.00Hz" 305.71 7680 7968 9120 9696 960 982 986 1051 interlace -hsync -vsync
>>modelist install
Mode "2560x768_60 31.47KHz 60.00Hz" rejected by driver.
Mode "2560x800_60 31.47KHz 60.00Hz" rejected by driver.
Mode "2560x960_60 31.53KHz 60.00Hz" rejected by driver.
Mode "7680x768_60 31.47KHz 60.00Hz" rejected by driver.
Mode "7680x792_60 31.47KHz 60.00Hz" rejected by driver.
Mode "7680x816_60 31.47KHz 60.00Hz" rejected by driver.
Mode "7680x840_60 31.47KHz 60.00Hz" rejected by driver.
Mode "7680x864_60 31.47KHz 60.00Hz" rejected by driver.
Mode "7680x888_60 31.47KHz 60.00Hz" rejected by driver.
Mode "7680x912_60 31.47KHz 60.00Hz" rejected by driver.
Mode "7680x960_60 31.53KHz 60.00Hz" rejected by driver.
21 modelines installed.
« Reply #94 on: May 30, 2019, 12:47:56 pm »
Thank you.
Last (I swear) if you have a chance, no hurry, pass me a .reg file of this key in your system: HKLM\System\CurrentControlSet\Control\Video\{D39178CA-82E6-11E9-8904-99523214DC8F}\0000
At this point I can say I can't fix it from here. Everything is working as intended except the driver rejects the EDID for some reason. It works here with a newer Vega GPU, so I'm quite sure it's possible to get it working. But I'd need to do kernel debugging on the phyisical machine to figure out the issue. So I think it's time I bite the bullet and get the 2400G so I can play with it here.
Thank you for your time and the information you've provided, it's very valuable to me and to the project. I'm sorry that it didn't work. I can't test all gpus so what I usually do is to have a stock of cards that cover the lower and higher (or older-newer) range of the ones I want to support. So having success with the Vega 56 induced me to think the Vega 8 would work out of the box. I'd like to have checked this months ago but I have very little free time.
Cheers,
FrizzleFried
    • Idaho Garagecade
« Reply #95 on: May 30, 2019, 12:52:01 pm »
I will get that reg file to you today.  It appears my only path at this point is to install the Ryzen 1200 (it's at the local distribution point and should be here today) and go from there.
FrizzleFried
    • Idaho Garagecade
« Reply #96 on: May 30, 2019, 12:54:32 pm »
BTW... safe to continue using this VMmaker going forward or should I go back to the "normal" one?
FrizzleFried
    • Idaho Garagecade
« Reply #97 on: May 30, 2019, 10:27:06 pm »
Thank you.
Cheers,
See attached.   Now on to swapping APU/CPU...
FrizzleFried
    • Idaho Garagecade
« Reply #98 on: May 30, 2019, 11:09:06 pm »
...and with the CPU installed... 5 minutes later and...
The driver works exactly as I expected it SHOULD work too... glad I wasn't going crazy.
« Reply #99 on: May 31, 2019, 03:51:57 am »
It is safe to use it, it just shows more information in the console.
Thanks for your .reg, everything is setup correctly, it's an issue with the driver itself. I won't manage to figure it out until I get my hands on the hardware.
FrizzleFried
    • Idaho Garagecade
« Reply #100 on: May 31, 2019, 09:08:19 am »
FWIW since someone else had success,  it may be a MOTHERBOARD issue?   He was using an Asus MB and I have the cheapest Gigabyte money could buy... GIGABYTE GA-A320M-S2H
krick
  • Gotta have blue hair.
« Reply #101 on: May 31, 2019, 10:19:58 am »
There was a time when Gigabyte made fantastic motherboards.  I think that time has long passed.  I won't buy anything other than Asus now.
That said, it might be worth doing a side-by-side comparison of the specs on both boards to see if there's a hardware/chipset/component difference between the two boards that we can isolate as the cause for incompatibility.  Then in the future, we could just say that boards designed with "part x" are not compatible.  Though in reality, it might come down to a missing or incorrectly coded feature in the motherboard BIOS that could be fixed in a future update.
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
FrizzleFried
    • Idaho Garagecade
« Reply #102 on: May 31, 2019, 11:18:00 am »
Minor issue ... In ATTRACT-MODE even though my desktop is at 640x480i,  when I drop in to attract-mode it does so at 640x480p.... when I exit it goes back to 640x480i.   If I set the resolution to anything else,  it maintains the correct resolution / 15khz.... and of course all my layouts I've made for Attract Mode are at 640x480...
How do I "remove" 640x480p mode or otherwise prevent it from being used?
FrizzleFried
    • Idaho Garagecade
« Reply #103 on: May 31, 2019, 12:49:03 pm »
BTW... it appears that Groovymame is working with the resolution changer properly... and I have to say my emulated games have never looked quite as nice.
Awesome piece of software Calamity.
FrizzleFried
    • Idaho Garagecade
« Reply #104 on: June 01, 2019, 11:30:22 am »
I've noticed a distinct drop in speed between the VEGA 8 and the R5 220.   For example,  running the Vega 8 with a PC monitor I was dropping below 100% on Gauntlet Dark Legacy only twice during the whole attract mode... now it occasionally goes above 100% sitting around 80-85% most of the time.
This R5 220 is a piece of crap card to be honest... and after a bit of research I ended up picking up a factory reconditioned R7 250 which is a much better card while still retaining the VGA output.  I am HOPING that it's old enough (2013 introduced) that the VGA out will work with little fuss (PLEASE??)... but at $49.00 it was hard to pass (especially since this R5 220 was $39 and is going back).
Any insight on the R7 250?  Will it be as easy as the R5 220?  Will the VGA port work or am I going to have to fuss with HDMI again?
Thanks....
krick
« Reply #105 on: June 01, 2019, 12:45:05 pm »
I own a HD 7750 and I just picked up a low profile R7 250 off of Ebay last week.  They're both 1st gen GCN parts (Cape Verde Pro vs Oland XT) and they're almost identical performance-wise from what I've read.  I think the 7750 is supposed to have a few more shader units or something but at the end of the day I don't think it makes much difference.
So far, I've only tested the HD 7750 with CRT_Emudriver 2.0 and it works perfect.  I expect that the R7 250 to be the same.  If I get some time tonight or tomorrow, I'll try to toss it in my MAME PC to see how it works.
EDIT: Here's a comparison of the specs (from wikipedia) between the HD 7750 and the various R7 250 models...
EDIT 2: I found this useful list online that shows how the new card names map to the old names.
  • Radeon R9 290X = Hawai XT = new card
  • Radeon R9 290 = Hawaii PRO = new card
  • Radeon R9 285 = Tonga PRO = new card
  • Radeon R9 280X = Tahiti XT = Radeon HD 7970 GHz Edition
  • Radeon R9 280 = Tahiti PRO = Radeon HD 7950 Boost Edition
  • Radeon R9 270X = Curacao XT (Pitcairn XT) = Radeon HD 7870
  • Radeon R9 270 = Curacao PRO (Pitcairn XT) = Radeon HD 7870 reduced clocks
  • Radeon R7 265 = Pitcairn PRO = Radeon HD 7850
  • Radeon R7 260X = Bonaire XTX = Radeon HD 7790
  • Radeon R7 260 = Bonaire = Radeon HD 7790 with reduced configuration
  • Radeon R7 250X = Cape Verde = Radeon HD 7770 GHz Edition
  • Radeon R7 250 = Oland XT = new card
  • Radeon R7 240 = Oland PRO = new card
« Last Edit: June 01, 2019, 01:37:39 pm by krick »
Hantarex Polo 15KHz
FrizzleFried
    • Idaho Garagecade
« Reply #106 on: June 01, 2019, 05:01:45 pm »
Hmmm... I wonder what version of R7 250 I have... I got this:
https://www.newegg.com/msi-radeon-r7-250-r7-250-2gd3-oc/p/27N-0023-00083?Description=r7%20250&cm_re=r7_250-_-27N-0023-00083-_-Product
It says core clock of 1050 which tells me it's the older model though.... and the fact it has DDR3 confirms the fact.
« Last Edit: June 01, 2019, 05:04:39 pm by FrizzleFried »
« Reply #107 on: July 04, 2019, 02:58:36 am »
So yesterday I did my first tests with a Ryzen 5 2400G and I can confirm FrizzleFried's reports.
FrizzleFried
    • Idaho Garagecade
« Reply #108 on: July 04, 2019, 02:18:31 pm »
Very happy to have confirmation that I am... indeed... not crazy.
Well... not in THIS particular case.
« Reply #109 on: July 05, 2019, 05:04:44 am »
The thing is, I was excessively confident about the Vega 11 APU being supported since I had success with my Vega 56. The rule that worked for me in the past was that giving support to a newer card guaranteed support for previous models. What I was wrong about was assuming that Vega 56 (Vega10 XL) was newer than Vega 11, when it's actually the opposite (1 year older). Now I need to figure out why newer models are different so that the EDID emulation code isn't even executed in the driver.
