December 13, 2025, 01:06:26 pm
Home
Help
Search
Login
Register
News:
Support this site
Shop
Amazon
through our link. Thank you!
Well, that was weird. Outage sorted out. Thank you SirWoogie for saving the day!
Main
Monitor/Video Forum
CRT TV installed in cab with VGA RGB-->Scart cable - weird picture
Main
Restorations
Software
Audio/Jukebox/MP3
Everything Else
Buy/Sell/Trade
Project Announcements
Monitor/Video
GroovyMAME
Merit/JVL Touchscreen
Meet Up
Retail Vendors
Driving & Racing
Woodworking
Software Support Forums
Consoles
Project Arcade
Reviews
Automated Projects
Artwork
Frontend Support Forums
Pinball
Forum Discussion
Old Boards
Raspberry Pi & Dev Board
controls.dat
Linux
Miscellaneous Arcade
Wiki Discussion
Old Archives
Lightguns
Arcade1Up
Try the site in https mode
Site News
Unread posts
New Replies
Recent posts
Rules
Chatroom
Wiki
File Repository
RSS
Submit news
« previous
next »
Send this topic
Print
Pages: [
1
Go Down
Author
Topic: CRT TV installed in cab with VGA RGB-->Scart cable - weird picture (Read 2298 times)
repetto74
Trade Count:
0
Full Member
Offline
Last login:April 18, 2020, 02:10:00 pm
on:
May 07, 2019, 12:00:50 pm »
Hi Guys,
I am desperate to obtain a decent picture with the 15khz CRT TV I have installed in my cab (my previous arcade electronics has gone bad and the flyback is no more available). It is a 25" TV with scart inputs so I purchased a quality RGB to scart cable with +12v and +5v molex connector for the A/V commutation and RGB switch.
Unfortunately I cannot get past this video quality where the image looks dim and some weird horizontal lighter coloured bars appears where text is displayed.
What I am sure of is that the cable is not the cause. I have tried to connect a DVD player with a standard scart cable and I do have the same issue when displaying the DVD menu. What this can be? I have a lot of pots on the TV chassis I can adjust and also the focus and brightness on the flyback. Is that a problem with the sync?
https://ibb.co/JyYSZSP
https://ibb.co/r3DJB19
https://ibb.co/vvDSK75
https://ibb.co/zQ1hm61
Last Edit: May 07, 2019, 12:13:46 pm by repetto74
Logged
buttersoft
Trade Count:
+1
Full Member
Offline
Last login:
Today
at 06:01:40 am
Is running at 15kHz
Re: CRT TV installed in cab with VGA RGB-->Scart cable - weird picture
Reply #1 on:
May 09, 2019, 02:05:31 am »
Yer, might be a sync issue. What's the setup? Is it a PC, and if so, what PC, what OS, what GPU, how are you getting 15kHz, and composite sync? Does the VGA-to-SCART cable plug directly into the PC and go straight to the TV?
Logged
repetto74
Trade Count:
0
Full Member
Offline
Reply #2 on:
May 09, 2019, 04:01:08 am »
Hi Buttersoft,
It is a standard PC config of 2004 with 4 GB of Ram and two IDE HDD. I am using an ArcadeVGA video card at 15khz and the VGA to Scart cable is directly connected to the video card output and the TV scart input.
This setup was working with my past arcade monitor and had to remove it due to a bad FBT so I choose the option of placing a TV in the cab. I have tried to hook a DVD player directly to the TV scart and I do have the same issue when displaying the DVD menu so the issue has somehow to do with the TV set and not the PC config and cable.
The TV electronics has a lot of pots I can tweak like B+ voltage, Trap, Delay, all the screen size and shift. I did not touch any pot up to now and even no tried to turn the screen of the FBT yet.
UPDATE : Last time I took out the TV Pcb to unsolder the cable wiring I did myself from the scart pins as I do no need it anymore (brand new cable directly connected to the Scart plug). By mistake I did turn the pot for the B+ adjustment just to check with the screw driver then I moved it more or less to its original position. Now the TV won't turn up (no raster) so I did check with a voltmeter at the check point for the B+ (It is a resistor so I put both voltmeter leads on each side of the resistor and I read only 65 VDC where it should be normally 155 VDC for a 25" monitor. There is not enough B+ voltage to carry on the FBT I hope this is the problem now cause I had a screen lighting up before moving the B+ pot.
Last Edit: May 09, 2019, 12:33:23 pm by repetto74
Logged
Mr. Peabody
Trade Count:
0
Full Member
Offline
Last login:November 11, 2025, 07:08:52 pm
Reply #3 on:
May 11, 2019, 06:00:36 pm »
B+ is the main drive. If your other issue(s) persist, show us some pictures.
Logged
repetto74
Trade Count:
0
Full Member
Offline
Reply #4 on:
May 12, 2019, 07:23:01 am »
Actually the situation is as follow :
I have measured the B+ at the Testing Point marked on the PCB (where a 68 kohms resistor is mounted) so red lead on one leg of the resistor and black lead to the box of the TV tuner, well I measure just around 87 VDC where I should read almost 155 VDC. Turning the B+ trim will just change the voltage range of about 7-8 VDC not more. So I am definitely missing voltage somewhere but the actual B+ is actual enough to drive the flyback and display a very dim image.
Turning the G2 pot on the flyback is very sensitive. The image changes from a full picture with retrace lines to no picture at all by just moving the pot a little bit. The "sweet spot" is just a dim picture.
The B+ is the problem. I have measured the resistance of the 68k resistor and I read 160-170 kohms fluctuating. Weird, I am supposed to read a value close to 68K.
Logged
Send this topic
Print
Pages: [
1
Go Up
« previous
next »
Main
Monitor/Video Forum
