Author Topic: Lighting a 3" Happ trackball  (Read 1836 times)
aevans0001
  • Last login:September 28, 2025, 03:54:22 pm
« on: May 04, 2019, 12:35:14 pm »
Hi all, Long time lurker here
I am in the starting phase of building my arcade and trying to narrow down what I need to buy for controls.  I already purchased 2 ultrastiks and my buttons.  I have in my possession a 3" Happ High Ball trackball that works well but I wanting to add RGB lighting to it and my ultrastik 360 controllers.   What is the best way?
I will also be buying another trackball, which kind should I buy?
Which spinner should I get?
adamcian
  • Last login:October 22, 2023, 12:14:33 am
Re: Lighting a 3" Happ trackball
« Reply #1 on: May 04, 2019, 02:09:49 pm »
I think the U-trac http://www.ultimarc.com/trackball.html from Ultimarc is pretty much the ‘de facto’ trackball these days and I use his RGB option that you can add (not sure if you can add his RGB module to a Happ ball, but you may be able to if you have a hole in the bottom).
For spinners, I personally prefer the TurboTwist 2 https://groovygamegear.com/webstore/index.php?main_page=product_info&products_id=268 from GroovyGameGear, but I know people like the one from Ultimarc also.
For RGB options for sticks there’s a number of solutions on the forum here. Just read through the ‘Project Announcements’ forum and you can see many different approaches for that.
aevans0001
« Reply #2 on: May 05, 2019, 09:33:00 pm »
Thanks for the options, do you by any chance know where I can buy dust washer leds?
gingecko
  • I'm working on it!
« Reply #3 on: June 21, 2019, 03:08:12 pm »
 :o
Not sure how those would work??
I'm working away on a cabinet and current plans are to re-use my 3" Happs trackball. It's still working quite well, so it's hard for me to part with it. If I do change my mind, I would buy the Ultimarc trackball in a heartbeat. I'm totally sold on the aesthetics of having an undermounted trackball alone. My control panel might be the last thing that gets finalized, as I go back and forth on device choices.
aevans0001
« Reply #4 on: July 20, 2019, 02:55:59 pm »
I ended up using my Happ trackball and the Groovy Gamer Electric ICE RGB Trackball Lighting Upgrade Kit V2.0.
I havent tried it out yet but the pictures on the website looks awesome!
bperkins01
« Reply #5 on: July 21, 2019, 08:36:27 am »
I just looked at this site - It would be pretty nice if I could use this kit to add color to my existing Happ 2 1/4" trackball unit and connect it to my Ultimate IO card.
I didn't see any documentation on it - did you get some?
