Author Topic: Mamewah internal error when I quit the program, after a Windows 10 update  (Read 2858 times)
executor999
I have been running Mamewah v1.62 with Mame v.120 flawlessly on Windows 10 64 bit for years until I installed a Windows 10 update. My LCD monitor is vertical oriented and set to 1024x1280@60Hz, 32 bit resolution. Before I updated Windows, Mamewah opened and quit with no issues, as shown in an old log file:
1/6/2016 8:42:26 PM Games list read: mame-0.lst
1/6/2016 8:42:26 PM Mode 1024 x 1280 @ 60Hz, 32bit colour selected after 1 attempt(s) at 1/2 second intervals.
1/6/2016 8:42:26 PM Layout selected: C:\mamewah_v162\config\layout.lay
1/6/2016 8:42:26 PM No. joystick devices attached: 0
1/6/2016 8:42:26 PM Ctrlr file selected: C:\mamewah_v162\config\mamewah.cfg
1/6/2016 8:42:26 PM Keyboard enabled
1/6/2016 8:42:26 PM Mouse enabled
1/6/2016 8:42:31 PM Current drive/directory selected: c:\mame
1/6/2016 8:42:31 PM Commandline run: c:\mame\mame.exe mooncrst {flags=209}
1/6/2016 8:43:26 PM Application quit: c:\mame\mame.exe mooncrst
1/6/2016 8:44:23 PM Mode 1024 x 1280 @ 60Hz, 32bit colour selected after 1 attempt(s) at 1/2 second intervals.
1/6/2016 8:44:27 PM MAMEWAH quit
After the Windows update was installed, this is what happens:
4/23/2019 2:35:52 PM Games list read: mame-0.lst
4/23/2019 2:35:53 PM Mode 1024 x 1280 @ 60Hz, 32bit colour selected after 2 attempt(s) at 1/2 second intervals.
4/23/2019 2:35:53 PM Layout selected: C:\mamewah_v162\config\layout.lay
4/23/2019 2:35:53 PM No. joystick devices attached: 0
4/23/2019 2:35:53 PM Ctrlr file selected: C:\mamewah_v162\config\mamewah.cfg
4/23/2019 2:35:53 PM Keyboard enabled
4/23/2019 2:35:53 PM Mouse enabled
4/23/2019 2:35:56 PM Current drive/directory selected: c:\mame
4/23/2019 2:35:56 PM Commandline run: c:\mame\mame.exe frogseg1 {flags=209}
4/23/2019 2:37:27 PM Application quit: c:\mame\mame.exe frogseg1
4/23/2019 2:37:27 PM Mode 1024 x 1280 @ 60Hz, 32bit colour selected after 2 attempt(s) at 1/2 second intervals.
4/23/2019 2:37:28 PM Mode 1024 x 1280 @ 60Hz, 32bit colour selected after 2 attempt(s) at 1/2 second intervals.
4/23/2019 2:37:31 PM Mode 1280 x 1024 @ 60Hz, 32bit colour not available
4/23/2019 2:37:31 PM Error: 5 Invalid procedure call or argument in CTRLR_FinaliseDI
4/23/2019 2:37:32 PM Mode 1280 x 1024 @ 60Hz, 32bit colour not available
4/23/2019 2:37:32 PM Error: 5 Invalid procedure call or argument in CTRLR_FinaliseDI
I welcome any input and advice. This has to be an easy fix. In the worst case scenario I can rollback the update since this is a dedicated emulator machine but I would prefer not to.
Thanks in advance.
« Last Edit: April 23, 2019, 05:48:24 pm by executor999 »
Nuexzz
I'm almost sure that you will have to modify your layout with the editor that brings mamewah to guide the resolution again.
you can also try
### Misc Settings ###
safe_mode                                 1
executor999
Setting Safe Mode to 1 worked! And the change didn't negatively impact anything else. Thanks so much for your insight.
Nuexzz
It would be nice to make a configurator for this frontend .. although they are a bit abandoned (I love it) I use it in my arcade booth
