Author Topic: 3D Games too fast (gauntlet, blitz, mace, fore etc)  (Read 3776 times)
Endprodukt
  • Last login:February 23, 2026, 12:12:40 pm
« on: April 21, 2019, 01:40:49 pm »
I have a problem of many 3D games being way too fast, some of them go to 400%, jumping all crazy.
I just updated from a 0.18# version to 207. Tripplebuffer usually took care of this. I guess I'm just missing something.
  • Last login:February 19, 2026, 06:15:36 am
Re: 3D Games too fast (gauntlet, blitz, mace, fore etc)
« Reply #1 on: April 21, 2019, 02:56:33 pm »
You probably have frame delay enabled in mame.ini. That's a bad practice. Frame delay must be adjusted per game. First, disable it in mame.ini. Then lauch each game that shown issues, and use the new slider in the internal ui to set frame delay to 0. Finally, use the specific inis you had for each game and besides triplebuffer, set -autosync 0.
Endprodukt
« Reply #2 on: April 21, 2019, 03:38:12 pm »
The reason it's set to one in the mame ini is that I read it has to be set to one to enable the slider. I manually set all frame delay settings per game. Also had framedelay 0 in the specific game ini. Will try at home.
« Reply #3 on: April 21, 2019, 03:51:49 pm »
Yes, you're right, that was in the old implementation. The new one no longer needs that and it also saves the changes without the need of editing ini files.
Endprodukt
« Reply #4 on: April 22, 2019, 04:24:15 am »
Okay,
So setting autosync to zero did the trick. Seems like Mame got really demanding on these games in the past. Gauntlet, Mace ran 100% and are pretty glitchy now. But also going faster sometimes, which is pretty strange.
Edit: I'm on a 3258 clocked at 4.5 GHz. Should be okay?
« Last Edit: April 22, 2019, 04:36:40 am by Endprodukt »
donluca
  • Last login:February 18, 2026, 09:05:50 am
« Reply #5 on: April 22, 2019, 03:42:10 pm »
Going by memory, but I had my 3258 OC'd to 4,8Ghz with only one core enabled and I was able to run almost everything at full speed (IIRC the Zeus platform still lagged and some other modern ones).
2.- Inflatable dolls
Endprodukt
« Reply #6 on: April 23, 2019, 02:46:39 am »
It could be very well the emulation status but it was running much better before without all the jumping.
