Author Topic: Are these CRT's worth fixing?  (Read 4980 times)
LevelByLevel Gamer
  • Last login:April 20, 2021, 07:50:49 pm
« on: April 07, 2019, 03:49:15 pm »
I have these crt's that were taken from Golden Tee's which can be seen where I removed them here https://www.youtube.com/channel/UCN25Sl8nR2pcbikBa2ZRZvQ below are the pics. One is fuzzy but works and the other "Popped" when I connected the converter board pictured to a raspberry pi and the color is out. I'm new to the hobby and the sight. My YouTube has some things like xx in x boards which I was told not to post direct links too for violation of forum policies (new to forum too  ;D) but I am under the impression that my channel in general does not violate.
I'm just your average 80's kid with a love for gaming. I have a retro gaming YouTube if you guys are interested https://www.youtube.com/channel/UCN25Sl8nR2pcbikBa2ZRZvQ
behrmr
Re: Are these CRT's worth fixing?
« Reply #1 on: April 07, 2019, 09:34:24 pm »
Yes. They are worth fixing.
« Reply #2 on: April 08, 2019, 10:16:32 am »
I'll take em if you dont want em.
LevelByLevel Gamer
« Reply #3 on: April 09, 2019, 06:47:02 am »
It would be nice to get them running in a retro cab but what would be a honest value to them in trade or sell?
keilmillerjr
  • Web Developer.
« Reply #4 on: April 09, 2019, 07:16:09 am »
Some people want $500 for just the monitor, some people give away the golden tee cab for free with a working monitor. I wouldnt worry about the value. Fix them. LCD does not compare. There is some great support here and on Facebook groups like crt collective.
LevelByLevel Gamer
« Reply #5 on: April 09, 2019, 05:31:20 pm »
Thank you so much for the feed back, I will keep them and dig into working on them. Another question is will the work in vertical and horizontal cabs? I have a Mr's Pac Man that is doing some weird stuff and the screen is looking dull and has burn in. One of these at full color might do the trick.
Gilrock
« Reply #6 on: April 10, 2019, 11:02:36 am »
I paid $500 apiece for 2 CRTs recently but for that price the CRT had been washed, re-capped, and possibly a tube swap because there was zero burn in and it included shipping.  So yeah you can get $500 but only after putting them into good shape.  Not sure what someone would pay for just the raw monitor pulled from a cab.
« Reply #7 on: April 10, 2019, 11:48:53 am »
There is no such thing as a vertical monitor. Its just a regular monitor turned 90 degrees.
LevelByLevel Gamer
« Reply #8 on: April 10, 2019, 01:54:01 pm »
 :banghead: "doht" I should have thought that through before I said that. I have a cocktail mrs pac man I need to figure out the issues and that screen is mounted vertical plus a xx in x board i used on one of those would only adjust to fit the bottom portion of the screen. I assumed (new to this) that some how some boards/monitors were designed or programmed to be mounted either vert or horizontal. I'm going to post a vid of what the pac man is doing in the arcade repairs section here shortly before night shift. Thanks for the replies guys  :D
Mr. Peabody
  • Last login:November 11, 2025, 07:08:52 pm
« Reply #9 on: May 07, 2019, 06:29:58 pm »
Pac requires a 19'' monitor.
Boards are PCBs. They are programmed. Monitors are not. Games are designed with the monitor orientation in mind, as the monitor (especially CRT) operates the same way regardless of game orientation.
  • Last login:Yesterday at 07:02:52 pm
« Reply #10 on: May 07, 2019, 07:03:22 pm »
You should be cognizant of mounting frames for monitors though.  Some people don't care whether their monitor is in a vertical or horizontal frame, this is apparent when you see conversions. But the proper mounting frame helps secure your monitor.
There's a guy on KLOV trying to sell a 19" K7000 for $500, which is absolutely ludicrous.   A rebuilt 19" monitor should cost around the $250 mark, IMO. A rebuilt chassis goes around $160 by itself. Tubes and frames shouldn't jump the price up to more than double the cost of the chassis.
Gilrock
« Reply #11 on: May 07, 2019, 08:45:57 pm »
Geez that was almost a month ago I said that...lol.  I'm happy with the purchase.  Probably was $100 just to ship the monitor.  I looked for a week and found no others in my area.
LevelByLevel Gamer
« Reply #12 on: May 12, 2019, 07:11:23 pm »
I have decided to keep these for future projects and as learning tools. My CRT knowledge is very limited. I did discharge the electricity with a grounded screwdriver and wire (nerve racking first time LOL). my next question is are these universal to all arcade cabs? thank you guys again for the responses  ;D
Mr. Peabody
« Reply #13 on: May 16, 2019, 05:54:52 pm »
Are what universal?
« Reply #14 on: May 16, 2019, 08:14:17 pm »
Are what universal?
the size and if the game requires standard or medium res are the only non universal things about arcade monitors.
LevelByLevel Gamer
« Reply #15 on: May 17, 2019, 10:03:58 am »
thanks, that's what I meant. these are from 1999 and 2000 golden tee's and did not know if I could use them in older cab repairs.
