Author Topic: Hantarex polo 25 power supply problem  (Read 1802 times)
Justez
  • Last login:March 07, 2026, 04:42:05 pm
« on: April 02, 2019, 08:30:01 am »
Hi
I'm fixing a hantarex polo 25 chassis 220v.
When I started, Power supply fuse was fused, so I replaced T101 (IRFBC30) IC101 (UC3842) and all electrolitics capacitors and diodes from primary section zener include.
The fuse is now ok.
I am using an isolation transformer to measure the primary.
In TP1 I get 45V, but in the secondary output in TP6 (B+) I only get an oscillating measurement between 0V and 5V, I use a 40w lamp as a dummy load in TP6, the lamp is on off, oscillating.
I wanted to know what tests could be done in power supply primary to know where is the problem.
Thanx
