Author Topic: Arcade osd command line  (Read 2820 times)
xbrunox
  • Last login:August 30, 2025, 05:03:06 pm
« on: March 31, 2019, 05:38:00 am »
Hi all there is a way for use arcadeosd in command line?
  • Last login:January 30, 2026, 08:05:28 am
Re: Arcade osd command line
« Reply #1 on: April 02, 2019, 06:22:10 am »
Not yet. I plan to implement it at some point. If you explain a bit what you're attempting to do it could be applied to the future implementation.
Recapnation
    • Eiusdemmodi
« Reply #2 on: April 02, 2019, 12:54:49 pm »
Switching video modes just by double-clicking an icon on the desktop would get some use here!
xbrunox
« Reply #3 on: April 02, 2019, 01:08:24 pm »
Hi Calamity
so.. I've a 25 Khz Monitor.
usually for change resolution i use Multires line command.
for use linbergs games i need to set my desktop at 640x480.
if i set 640x480 via multires i've always a black screen, probabily because multires set 640x480 at 31khz...
the only way that i've for set 640x480 at 24khz is use arcade OSD and at this moment i do this terrible thing with autoit...
un ("C:\roba_utile\crt_emudriver_&_tools_2.0_beta_14_16.2.1_W.7.8.10-64\arcade_osd.exe")
Sleep(3000)
Send("{1}")
Sleep(100)
Send("{down 3}")
Sleep(100)
Send("{1}")
Sleep(100)
Send("{down 4}")
Sleep(100)
Send("{1}")
Sleep(100)
Send("{down}")
Sleep(100)
Send("{1}")
Sleep(100)
Send("{esc 2}")
this is why i'm looking for a command line..
many thanks.
nexusmtz
« Reply #4 on: April 02, 2019, 10:55:13 pm »
Not exactly what you asked for, but nircmd's setdisplay option lets you specify refresh rate. That might work for you until Calamity adds the feature.
xbrunox
« Reply #5 on: April 03, 2019, 12:18:53 am »
In multires command lines options too I can specifafy refresh rate and colors depth, bur unfortunally the change of these options don't solve the problem.
