Author Topic: Taito Type X Games - Prevent Auto Rotate  (Read 3043 times)
champrt78
  • Last login:December 03, 2021, 01:49:14 pm
« on: March 20, 2019, 12:07:21 pm »
Hello all,
I have a Hyperspin setup with a 42' tv mounted vertically. Everything runs fine except Taito Type X/X2 games. Vertical games such as Raiden III and IV auto rotate my screen. I found a hacky way to get Raiden IV to work tho, I have a batch file that runs after the game loads that rotates my screen 90 degrees , then when the game auto-rotates to adjust it is actually right. It doesn't work for Raiden III tho, I swear it worked once , but never again. Anyway is there a way to disable the Auto Rotate when these games launch? Has anyone figured this out? Im not sure where it does it, somewhere in the ahk ? Im just not that familiar with Hyperspin and Rocketlauncher to figure it out.
Guywiththegun
  • Last login:February 17, 2020, 12:00:21 pm
Re: Taito Type X Games - Prevent Auto Rotate
« Reply #1 on: March 23, 2019, 08:30:15 am »
How are you launching the games? Don't use those .bat files that come with the game download. Use Gameloader All RH .. it has a ton of options to run these games however you want. There's a checkbox for rotating the screen (or not). I actually wish it could be used for everything, its so useful.
