Author Topic: Gyruss Restoration and Possible Addition of Jamma Adapter and 421-1 Cart  (Read 4826 times)
BuckNasty
  • Last login:June 04, 2020, 08:09:00 pm
Greetings all.
I have a Gyruss machine that I just got up and running after two years of it not working properly. Turns out it was as simple as adjusting the voltage on the power supply. Now I'm planning on going down the path of fully restoring it. It's actually in pretty good shape. I'll try to post pictures later when I get home from work. I may start a blog to document it or just document it on here. The list of things I need to do are:
-Repaint the cabinet and coin door
-Get and install new bulbs for the coin acceptors
-Fix and ultimately convert the marquee light to LED
-Resolder one of the speaker wires to the volume control inside the coin door
I haven't decided if I'm going to replace the control panel overlay. Mine is in pretty good shape. It really just has one spot where the vinyl has been worn through. I do plan to disassemble the control panel and give the buttons and joystick a thorough cleaning.
I am also interested in adding a Jamma 421-1 to the machine. I plan on leaving in the stock PCB and leaving the control panel stock. The plan is to add a Konami to Jamma adapter and add the card so that we can use it as a multi-cade, but easily convert it back to stock when we finally get around to building a multi-cade from scratch.
I'd love to hear from anyone about the pros and cons of the things I have listed. I know that repainting cabinets using stencils can be a bit of a hassle, but I figure if I'm going to do it, i might as well do it right.
« Last Edit: March 19, 2019, 03:41:02 pm by BuckNasty »
  • Last login:Today at 12:32:30 am
Considering Gyruss uses a Monroe joystick that pivots, you’re not gonna have much fun putting games like Donkey Kong or Pac-Man to the cab. Just start building the multicade.
BuckNasty
Yeah, I've considered that. I'd still like to give it a go, as we won't be able to start on the multitude until this summer. The Gyruss restore is underway, at least parts have been ordered, and I thought adding a jamma cart to it might add a little spice to the project.
BuckNasty
Can anyone suggest the base black for the cabinet and what folks have used to paint the coin doors? I have. I saw a suggestion of automotive paint. Would I be able to paint both the cabinet and the coin door using the same paint?
Throwing a multicart into a classic cabinet automatically disqualifies it as a restoration, and puts it into conversion territory.
This should probably be moved to Project Announcements.
That being said, most of the games in that multicart use more than 1 button. Are you planning on putting holes into the original panel?
Also, I vaguely remember this cart doesn’t like -5v, how are going to handle that? Are you going to build a Gyruss to JAMMA harness and just not include the -5 in the conversion?
Gyruss is a classic, and the cabinet is a wonderful piece of history. It was the first arcade game to host stereo sound output, which was merited by the awesome classical soundtrack. I remember trying Gyruss on those Game Elf carts and the sound being off in a few games including Gyruss.
Personally I’d keep this as a straight restore, but it’s your stuff - you do you.
  • Last login:Yesterday at 11:36:27 am
I will cry if you rape that Gyruss cab.
BuckNasty
Please let me be clear, I don't plan on altering the cabinet(other than some sanding, painting and the other updates mentioned in my original post), altering the control panel, or removing the PCB. Everything is in relatively good shape, even the CRT, for a 36 year old machine. I just spent an hour sanding the Centuri badge from the coin door and will be painting it on Friday. I did purchase a Konami to Jamma adapter and a multicard. I thought it might be fun to hook it up while I'm already mucking around with the machine. Ultimately, the multicart will be used for a separate multicade project. I have an empty space firebird cocktail(sans controllers) that my son is currently using as a desk that I'd love to work on this summer. In the meantime I'd love to be able to test it out the multicart and try some of the one button games in the Gyruss cabinet.
BuckNasty
Far from my plan. The Gyruss is simply what I have. I saw that there were adapters out there that would allow me to swap in a jamma multi, without gutting the machine, and I thought it might be fun to play around with.
I am glad to hear that. Gyruss is a great game.
