Author Topic: Megatouch ion freezing during games  (Read 6456 times)
Rscardino10
  • Last login:March 13, 2019, 01:14:44 pm
« on: March 10, 2019, 06:19:03 pm »
Hey everyone
I have a megatouch ion that has recently started freezing during games. It appears to only freeze when the screen is being touched. Games run fine besides that.
Any ideas?
mahkeymike
  • Last login:Yesterday at 03:58:50 pm
Re: Megatouch ion freezing during games
« Reply #1 on: March 10, 2019, 10:04:02 pm »
Hey everyone
Any ideas?
Well, if the games are running fine, just dont touch it.
  • Last login:Yesterday at 03:27:41 pm
« Reply #2 on: March 11, 2019, 12:27:05 pm »
check your power lead ground. if it's been snapped off or you have a bad plug, your static build up can cause all sorts of random issues when you touch it. might not be an issue all the time, but if you have started having especially dry days, it can become an issue.
the power supply could be failing as well. the screen runs off of +12v directly from the power supply, if this voltage has started going low, the overlay can do weird things like pulling the voltage down so low that the +12 used for the CPU gets spikes,dips and other nasties going through to the CPU.
i've seen something a weird as buzzing fluorescent lights causing crashes. your body becomes a giant antenna when you touch the screen so any stray fields can be plotzed into the machine. so the big magnetic/electric field you transmit through the machine from failing fluorescent light ballasts when you touch it can cause this too.
it's a matter of finding out what's changed since it last worked. if nothing has changed, i'd look into reloading the software (since it's free to do that) and if it's still does it...replacing the power supply. it's probably due anyways if it's original to the machine.
Rscardino10
« Reply #3 on: March 11, 2019, 02:12:58 pm »
Thank you for the response. I should have also mentioned as well.. every 10 or so times I boot the machine I get an error saying “power saving mode, dsub analog”... does that have anything to do with the freezing and or are they related?
« Reply #4 on: March 11, 2019, 03:44:58 pm »
sounds like it could be ram related. that message is generated by the LCD panel itself when it doesn't receive a VGA signal.
try reseating the RAM and see if that helps.
