Author Topic: GroovyArcade - Does GroovyArcade run 1:1 resolutions or Super Resolutions?  (Read 2078 times)
jimmyj1979
  • Last login:May 02, 2022, 07:26:01 am
Hey all
Still trying to find the source of bad video with my set up, the only thing left now is whether or not it has to do with GroovyArcade & Linux
Does GroovyArcade run 1:1 resolutions or does it do a super resolution of 2560x240 and then 10x the Horizontal Pixels?
Also, what exactly does the forcedotclock_min do? Mine is set to 0 and always has been, what have i missed there?
Calamity
  • Moderator
  • Last login:Today at 05:20:14 pm
  • Quote me with care
Hey all
It uses native 1:1 resolutions unless you force it otherwise. The dotclock_min option sets the minimum dotclock that modes will be calculated with, if calculations result in a lower dotclock than this value, the mode will be scaled by 2 horizontally, until the minimum dotclock condition is met.
Steps to create a log:
invzim
  • Last login:July 27, 2022, 07:41:37 am
What's the intended behavior for 31k only monitors?  I had a play with it yesterday on an old motherboard and the output video looked a little soft/blurry.
