Author Topic: ArcadeVGA to Hydra SCART switch  (Read 1998 times)
grackle
  • Last login:February 24, 2019, 12:19:07 pm
« on: February 24, 2019, 08:52:45 am »
Hello, I have an ArcadeVGA PCIe that works great when connected directly to my Sony PVM via a VGA to BNC cable. I wore R to R, G to G, B to B and use a BNC joiner to merge black and grey sync (H/V) into one sync signal and put that into the sync input of the TV. That works great.
I would rather have this plugged into my SCART switch, the Hydra from Lotharek. That switch has a series of female SCART connectors and routes the active one to the PVM. it works great with my SCART consoles.
I acquired a BNC to SCART connector from eBay with the SCART side set up as output. For whatever reason, the signal flickers on and off and is “swirly” when on, indicating the sync isn’t working. Since it works great without the SCART or switch path, I figure I don’t understand how that all works. Any tips here? In the best case I’d love a VGA TO SCART output cable that known works with the ArcadeVGA. Thanks
buttersoft
  • Last login:Today at 03:31:50 am
  • Is running at 15kHz
Re: ArcadeVGA to Hydra SCART switch
« Reply #1 on: February 25, 2019, 09:35:29 pm »
Errr. Firstly, which adapter are you using, and how is it wired? I think you’re trying to go from the PC via the VGA port > VGA-to-5-BNC cable > 5-BNC-to-SCART adapter > Lotharek Hydra – is that right? (if the adapter is a 4-BNC-to-SCART one, you’d just use your T-piece joiner again). The SCART cable should be setup for input, because it’s inputting the signal to the Hydra. You might be able to open it up and rewire it, or perhaps slide pins 19 and 20 out and swap them, if that sounds right. That said, if the Lotharek isn’t just passing the sync right through, you might have a problem. And VGA outputs TTL level sync (+5VDC) so while a PVM is happy enough to take 5Vp-p sync assuming nothing ever goes wrong, a SCART TV might not work regardless, IDK.
Regarding buying a new cable - most (VGA)HD15-to-SCART cables are only wired with H-sync, not V-sync. This is because composite sync would be carried over the H-sync pin, pin 13, and the cables were normally used to connect projectors to other gear, not for PC use. If do not think the ArcadeVGA can be made to output composite sync, you’d have to look into that. There are some VGA-to-SCART cables out there that will combine sync, or there used to be, like this one: https://www.ebay.com/i/141663388712?chn=ps&dispItem=1
Building a VGA-to-SCART cable isn’t impossible, if you know how to solder. Or, try contacting Andy from Ultimarc and asking for suggestions connecting an ArcadeVGA to a SCART TV. Or google it, and see what you think of the results :)
