Author Topic: Flickering filter on interlace resolution.  (Read 2002 times)
m.andrade1
  • Last login:April 10, 2025, 09:05:35 am
« on: February 20, 2019, 07:08:32 am »
Hello Guys
Just wondering if "flickering filter" can be turned on on recent crt_emudrivers, as Calamity remove it since beta 11, i´m stick will beta 10 yeat.
Any way to have this fearture again ?
Marcos
buttersoft
  • Last login:Yesterday at 07:21:06 pm
  • Is running at 15kHz
Re: Flickering filter on interlace resolution.
« Reply #1 on: February 20, 2019, 08:17:56 pm »
I'd like an option to turn it back on as well, i much prefer having it. I can't remember if Calamity has already ruled it out though :/
  • Last login:Yesterday at 12:00:46 pm
« Reply #2 on: February 21, 2019, 04:17:10 am »
It's not as simple as adding an option. A binary patch is applied to the driver to remove the filter. Then it has to be signed and packaged. The only solution is to mantain two separate packages.
You can use current CRT Tools over the older driver anyway.
In the future I'd like to drop my installer and adopt a different solution that allows more flexibility.
