Author Topic: 31Hz games runs on a 15Hz graphic card ?  (Read 29735 times)
  • Last login:Today at 11:36:56 am
Re: 31Hz games runs on a 15Hz graphic card ?
« Reply #40 on: February 13, 2019, 04:27:27 pm »
Did the game look crushed in this case?
Yes
I just removed the line "orientation rotate_r" that I created, and I changed the word "horizontal" by "vertical" in the core switchres options but the clatter still occurs when i launch GroovyMAME, and when i launch a game.
That, plus the game llook crushed too
Please only try from command line until you get it sorted out.
Restore "orientation rotate_r"
Obviously I mean that were you just wrote "vertical" you now write "rotate_r".
run: mame64 1941 -unevenstretchx 0 -unevenstretchy 1
« Last Edit: February 13, 2019, 04:29:43 pm by Calamity »
Gandalf68
  • Last login:March 27, 2019, 11:14:05 am
  • Arcade is the best thing after sex !
« Reply #41 on: February 13, 2019, 04:45:08 pm »
OK sorry, my bad.
I did it and i get a list of games, mostly the games in the 19xx series
EDIT : But i just realized that i forgot to type "1941" after mame64
« Last Edit: February 13, 2019, 05:00:33 pm by Gandalf68 »
« Reply #42 on: February 13, 2019, 04:51:53 pm »
My bad, type it this way:
mame64 1941 -nounevenstretchx -unevenstretchy
Gandalf68
« Reply #43 on: February 13, 2019, 04:57:46 pm »
With that command line -> no clatter and the resolution is perfect !
So, what is the next step ?
« Last Edit: February 13, 2019, 05:03:31 pm by Gandalf68 »
« Reply #44 on: February 13, 2019, 05:12:00 pm »
Ok, so create an ini file named vertical.ini (put it in MAME's folder) that *only* contains these 2 lines:
unevenstretchx 0
unevenstretchy 1
That should fix it. Now you should be able to launch GM from your usual frontend.
I'm not sure if the issue when launching games from GM's internal ui is fixable. Does it appear in the correct orientation or you have to lean your head?
Gandalf68
« Reply #45 on: February 13, 2019, 05:34:52 pm »
When i launch GM, the menu is still rotated and i hear the clatter.
And after that, i hear it when i launch a game too.
But the games are in the correct vertical position and the correct resolution.
Exactly ! It worked !
But there is still two problems :
- Hyperspin is displayed rotated
- For some reason, now the music in games is distorded, like a record that slows down
(I also noticed that since we set my desktop to 648x486@60 -> the video previews in Hyperspin are jerky)
« Last Edit: February 13, 2019, 05:36:40 pm by Gandalf68 »
« Reply #46 on: February 13, 2019, 05:46:51 pm »
Rotated desktop seems to cause older video cards to struggle. That's the cause of the sound issue (actually overall speed issue). If your system can't cope with that, then you'll need to go back to non-rotated desktop. That will also fix your other orientation issues (GM's menu and HS). Once you modifiy the desktop orientation, leave mame.ini unmodified (I mean, keep rorate_r), and delete the vertical.ini file you just created. I'd say it should work right away just with that.
If videos are jerky on HS, try disabling Aero. I don't provide support for HS anyway (I'd prefer no one used it with GM actually).
« Last Edit: February 13, 2019, 05:48:22 pm by Calamity »
Gandalf68
« Reply #47 on: February 13, 2019, 06:03:21 pm »
You truly are a magicien -> it worked exactly as you say so !  :applaud:
I rotated my desktop back (90 degrees) and Hyperspin is displayed correctly, no clatter, no sound distortion, perfect resolution !  :notworthy:
EDIT: Oh, and disabling Aero was indeed the right thing to do to fix the jerky videos  ;)
However , i tried several games just to check, and oddly, i found one game that still gives me the clatter
Here is the log, hopefully you'll figure out why ?
Alas, as for me, like yesterday night, i have to go to sleep because i'm working early.
One more time, thanks a lot for your help, and see you tomorrow !
« Last Edit: February 13, 2019, 06:12:28 pm by Gandalf68 »
Recapnation
    • Eiusdemmodi
« Reply #48 on: February 13, 2019, 07:03:44 pm »
You're getting that with a game which indeed calls for 640 x 480 at some point (ZN System-based) and you still have a tri-sync preset, ergo GM switches to 31-kHz.
(TATE)
Shmups
(My poor eyes.)
Gandalf68
« Reply #49 on: February 14, 2019, 07:05:03 am »
So how can I prevent it from going into 31kHz?
« Reply #50 on: February 14, 2019, 07:10:34 am »
Create an empty .ini for that game, then add:
resolution 2560x240
changeres 0
Gandalf68
« Reply #51 on: February 14, 2019, 07:31:38 am »
Ok, and can I do the same thing with all the other games that will want to get into 31kHz ?
Recapnation
    • Eiusdemmodi
« Reply #52 on: February 14, 2019, 07:53:37 am »
Calamity suggested that because Sonic Wings Limited is permanently 240 x 320 in-game despite the BIOS/driver reports, but if you do that for a genuinely hi-res game, the result would be hardly tolerable and what you'd want is preserving their resolution but in 15-kHz (interlaced). So in your case you should consider using a 15-kHz-only preset. Doing that is a shame and counternatural given the monitor you have, especially for the 24-kHz pieces, hence Calamity didn't contemplate such a radical approach.
« Last Edit: February 14, 2019, 08:45:39 am by Recapnation »
Gandalf68
« Reply #53 on: February 14, 2019, 08:20:08 am »
Oh ok.
I can understand that it is a shame to restrict a tri-sync monitor to only 15kHZ, but i really don't mind.
In fact, i assembled this MAMECab exclusively to play oldschool arcade games, nothing fancy.
I'm sticking to MAME, i will never play Console games nor recent games.
So the only thing i have to do now is to set Wmmaker to Arcade 15kHz ?
Gandalf68
« Reply #54 on: February 14, 2019, 08:27:02 am »
Or at the very least, i could make a .ini file for each games that wants to run in 31Khz ?
I guess there are not many anyway -> I have about 350 games in my list
Recapnation
    • Eiusdemmodi
« Reply #55 on: February 14, 2019, 08:48:48 am »
You could go with any approach, really. I think it's possible to even have a tri-sync preset and get hi-res games displayed in an interlaced mode. Be aware that your intention though is turning this:
...into this:
...or this:
(Hopefully you aren't on mobile when seeing this.)
Again, consider your options well.
Gandalf68
« Reply #56 on: February 14, 2019, 09:23:34 am »
I think i will try to create an .ini for all the games that "ask" 31kHz, but can i write the same lines for each of them ?
resolution 2560x240
changeres 0
Or do i have to write lines specific to each games ?
I'm on my PC, but the only difference I see between each picture is the size
« Last Edit: February 14, 2019, 09:26:22 am by Gandalf68 »
« Reply #57 on: February 14, 2019, 01:00:15 pm »
resolution 2560x240
changeres 0
Unless the 31 kHz mode switch is bogus like in the specific case of Sonic Wings, I wouldn't bother doing what you intend to do. Some sporadic clatter is much better than ruining the graphics, and there are not so many titles that switch to 31 kHz that I'm aware of.
Gandalf68
« Reply #58 on: February 14, 2019, 01:55:52 pm »
I think you're right, and I'll follow your advice  ;)
Once again, i would like to thank you Calamity (and Recapnation) for all the help you gave me  :notworthy:
Thanks to people like you, we, arcade enthusiasts, can relive many magical moments from our youth, and these are priceless...
