Author Topic: A new way to create LEDBlinky Animations  (Read 7094 times)
Gilrock
« on: February 03, 2019, 05:21:01 pm »
I just got LEDBlinky running on my control panel yesterday.   As I was playing with the animation editor I realized I could probably use the xLights program I'm a developer for to create animations that run with LEDBlinky.  So I spent a few hours this morning and I already have it working.  As we do with our Christmas shows it allows you to create effects at more of a macro level instead of setting individual channels although that is still an option.  I made a video that shows how I did it.  If folks are interested I can polish it up and add it as a feature to xLights.  You'll see me use a 3D model of my control panel but that is optional you could still do everything I did without the 3D model.  I don't know all the hardware codes or other details of the animation file format (.lwax) files so currently its hard-coded and works with my Ultimarc Ultimate I/O board.  I'd need input from others or the LEDBlinky author to know how to make it flexible enough for everyone.
brandonled
  • Last login:November 25, 2019, 04:15:49 pm
Re: A new way to create LEDBlinky Animations
« Reply #1 on: November 11, 2019, 04:40:07 pm »
Found this post and wanted to follow up.  It looks like this support made it into 2019.10 xlights conversion tool but I couldn't locate any additional information about what level of support is there and what LED Controllers would be supported (Your video mentions it used hard coded ultimate IO board information).  I was quite delighted to see you were working on this support and wanted more information.  Thanks.  (Tried to PM you but that's disabled???)
  • Last login:Today at 05:32:11 pm
« Reply #2 on: November 11, 2019, 04:54:19 pm »
First post approved.  Your PMs are now enabled.   :cheers:
Gilrock
« Reply #3 on: November 11, 2019, 05:10:15 pm »
Its in xLights official release now.  Its been awhile since I added it but I believe its under the Export Model option when you right click the row heading for a model.  I kinda did it mainly as a technical challenge because I don't find myself really wanting to create a bunch of animations.  It works with the Ultimate IO board cause that's all I own.  Let me know what you were looking for.  If you don't know the xLights program it can be a bit a learning curve because it has tons of features to create professional level light shows.
sorli
  • Last login:March 07, 2022, 06:50:15 am
« Reply #4 on: June 04, 2020, 10:02:59 pm »
Any new information about using xlights to output animations for the Ultimarc Ultimate IO? Do you have any website or forum link I can reference using your code ideas and addons? Thanks Sorli
Sent from my Touchpad using Tapatalk
Gilrock
« Reply #5 on: June 08, 2020, 10:44:08 am »
I haven't created anything new.  There is a ton of xLights information including forums and Facebook groups just goto xlights.org.  You will be hard-pressed to find any users that use this feature though but its really just an extra format for exporting so if you learn any method for exporting effects on a model you can just pick the LEDBlinky animation type for the export.  I had one other person here that got it working.  Its kind of a learning curve to learn xLights so I really don't expect anyone to invest that amount of time just to create some animations.
sorli
« Reply #6 on: June 12, 2020, 02:25:36 pm »
wtstreetglow
  • Last login:January 03, 2024, 05:00:14 pm
« Reply #7 on: November 08, 2023, 03:46:46 pm »
@Gilrock. I would also like to use xLights to program a few sequences for my control panel but would like to be able to use the sequence with LEDBlinky. I am reasonably familiar with xLights but have no experience with LEDBlinky as I have just recently built by arcade unit.
I have the PAC64LED rgb controller from ultimarc rather than the ultimate. Can you tell me if the process spoken of there will work with the PAC64LED.
I haven't watched your video just yet but am planning on it shortly and just wanted to get a little diaglogue from someone such as yourself-- much more knowledgeable than myself in both subjects spoken of here (xLights/ LED Blinky).
Thank you again for any guidance you can give as a start on this process!
-Weston
