December 12, 2025, 06:00:18 am
If you pull the key out of the osd board, do you get a "no key detected" error? Im wondering if your key's battery died. Also try taking the key out of the osd board and put it in the IO board to rule out bad wiring going from the osd to IO.
I had installed 2004 ... in the process of getting the 2010 version...I'll install that and let you know what happens.Thanks for the help btw.
