Author Topic: Broken micro-switches work with Led-Wiz Clone 2  (Read 1121 times)
Ron_Michallick
  • Last login:October 04, 2025, 06:58:37 pm
  • MK64 has newer software, if you are interested.
    • MK64
« on: January 13, 2019, 07:21:36 pm »
I have found that micro-switches that fail (using 'normally open' contact) usually have a working 'normally closed' contact.
With a small software change one can invert a joystick button input on the ledwiz clone panel.c file to match the normally closed connection.
Code: [Select]
uint8_t joy_b = 192;   //was 0 ; Joy button 7,8 being inverted.
case J1_Button1:
case J1_Button2:
case J1_Button3:
case J1_Button4:
case J1_Button5:
case J1_Button6:
joy_b |= JoyButtonBit(key);
break;
case J1_Button7:
case J1_Button8:
joy_b &= 255-JoyButtonBit(key);
break; //set inverted bit
