Author Topic: 25 khz Modeline on 15 khz - 31 khz Dual Monitor  (Read 2500 times)
philexile
  • Last login:October 30, 2022, 03:45:01 pm
  • I want to build my a GroovyMame PC!
« on: January 12, 2019, 03:04:03 pm »
Hello,
I have a monitor that is compatible with the 15 khz - 31 khz dual profile. It works great, but 25 khz games such as Paperboy look letterboxed due to the 384 vertical size.
Is there a way to stretch these games vertically to better fill the screen?
Thank you
Calamity
  • Moderator
  • Online Online
  • Last login:Today at 06:10:10 am
  • Quote me with care
Re: 25 khz Modeline on 15 khz - 31 khz Dual Monitor
« Reply #1 on: January 13, 2019, 02:04:31 pm »
You have to tell GM you don't want 384p.
You do so by adjusting the line limits of your crt ranges.
Currently you probably have a 31 kHz that allows 320p-480p. Fix that to only allow 400p-480p. GM will adapt to the new situation by stretching the games over the most suitable resolution.
Steps to create a log:
