Author Topic: Sega Model 2 Steering Wheel Controls  (Read 5204 times)
kicking1980
  • Last login:September 18, 2023, 02:38:50 pm
« on: January 08, 2019, 01:02:57 pm »
Hey guys I am having an issue with Sega Model 2 emulator and my Logitech g920 steering wheel. No matter what analog settings I change the emulator will not detect the steering wheel. I have used an Xbox One controller which worked. The issue is I have a lot of devices connected to my arcade. 4 spinners, one trackball and 2 light guns witch are all mouse devices. I changed the INI file for multiple mice but still nothing. All I get is the choice of generic gamepads and I have to go through all 4 plus all the axisa options to see if it worked. Does anyone have some suggestions besides unplugging all other devices to get it to work?
MydknyteStyrm
  • Last login:March 20, 2024, 12:19:41 pm
  • Makeup FX Gamer
Re: Sega Model 2 Steering Wheel Controls
« Reply #1 on: January 10, 2019, 05:06:02 pm »
I found that I had to unplug all other USB controls first (four U360s two Aimtraks, Trackball and Spinner) and then I configured my Logitech no problem. Model 2 Emu has a bug where it can’t read analog well if there are multiple USB controls in at once. Hope it helps!
Sent from my iPhone using Tapatalk Pro
kicking1980
« Reply #2 on: January 10, 2019, 07:35:35 pm »
I am just worried Windows will reorder all my controllers again..
kicking1980
« Reply #3 on: January 16, 2019, 04:43:39 pm »
I tried unplugging everything except the wheel over the weekend and model 2 still won't recognize it
« Reply #4 on: January 17, 2019, 05:53:02 am »
Do you still have xinput enabled from when you were using an Xbox controller?
patrickfx1
  • Last login:November 29, 2023, 11:38:48 am
« Reply #5 on: October 24, 2022, 07:49:29 am »
5 years later, same issues :) When multiple USB device, it does not work , crash when i try to select my wheel.  If you unplug all USB device, then I am able to select my wheel, thrustmaster in my case.  But then, when plug again all USB device.  The device not stay in SEGA model 2.  Very annoying !
