Author Topic: screen rotated 90 degrees - another noob mistake?  (Read 2625 times)
jjjxlr8
  • Last login:January 05, 2019, 02:10:18 am
« on: January 04, 2019, 07:34:55 pm »
So I hooked up a 60-1 Jamma board to my Arcade 1Up Deluxe machine this evening.  I have VGA running out of the 60-1 PCB to a board that interfaces with the 17" LCD screen.  That board has another board connected that has some basic adjustments for size, brightness, etc.  I didn't realize that I wouldn't be able to rotate the screen through software settings or dip switch settings.
I assume that I'm going to have to physically rotate the screen at this point?  Is there any way to salvage this?
jjjxlr8
Re: screen rotated 90 degrees - another noob mistake?
« Reply #1 on: January 05, 2019, 02:10:18 am »
Problem solved.  I had to physically rotate the screen 90 degrees.  It seems that the Arcade 1Up Galaga is a vertical screen where the Deluxe model is a horizontal.
negative1
  • Last login:February 28, 2026, 07:19:30 pm
« Reply #2 on: January 05, 2019, 09:20:56 am »
Nice job.
I prefer the joystick more in the center. But to each their own.
later
-1
