Author Topic: Can't Install 2.0 Beta 14  (Read 2381 times)
shredward
  • Last login:January 03, 2019, 02:59:50 pm
« on: January 03, 2019, 02:31:55 am »
I could use some help...
Trying to install CRT Emudriver for a HD6450, but when I run setup.exe no compatible devices are listed and thus the install driver button is greyed out.
schmerzkaufen
  • Last login:April 16, 2025, 09:46:43 am
  • Multiple Electronic Machine Emulator
Re: Can't Install 2.0 Beta 14
« Reply #1 on: January 03, 2019, 06:09:29 am »
"Have you tried turning it off and on again ?"
Joke aside that happened to me not too long ago, the card only appeared (listed as a generic VGA graphics card) after a power cycle or two.
The first time it simply was not detected, don't know why...
shredward
« Reply #2 on: January 03, 2019, 02:01:54 pm »
Yes, I tried the on/off switch!  :)
W7 wouldn't recognize the HD6450 either and listed it as a standard VGA adapter, so i thought that was a possible reason CRT Emu wasn't recognizing it as a supported card. I finally got that resolved, but to no avail. I've tried DDU, changed cards (I have two 6450s), and a bunch of other stuff - no joy.
Any other ideas?
Calamity
  • Moderator
  • Last login:Today at 04:34:20 am
  • Quote me with care
« Reply #3 on: January 03, 2019, 02:06:44 pm »
Make sure you're downloading the file ended as "_nieg"
Steps to create a log:
shredward
« Reply #4 on: January 03, 2019, 02:59:50 pm »
Will do...I see that option now that Eiusdemmodi is back up!
Thanks for your help and for all of the work you put into this!
