Author Topic: Monitor removal - Can I remove before discharge?  (Read 2150 times)
solocon
  • Last login:February 10, 2021, 02:45:27 am
« on: December 29, 2018, 09:08:19 am »
Been dong some research on removing the CRT monitor and the required steps to discharge the monitor.
The issue I'm having is I can't get up and under the plug without my arm extending touching the metal frame as I reach for the plug.
The person before me used wood and nails and sealed the back part of the box leaving a small opening (after removing 4 screws to ravel opening). (See attached pic)
I plan to remove the screen and replace it with a LCD screen. I have a GBS 8100 but could not get it to work with this monitor and seems the LCD would be a better route to go. (Play newer games if needed)
My question is, can I remove the monitor (including the monitor rails and boards) from the box and discharge it once out and easier to get to?
Re: Monitor removal - Can I remove before discharge?
« Reply #1 on: December 29, 2018, 11:41:18 am »
You don't have to discharge it to take it out of the cab. You have to discharge it if you're removing the chassis from the frame and tube.
solocon
« Reply #2 on: December 31, 2018, 03:13:19 pm »
Thank you! Just what I needed to know. Took the monitor out and did the needful!  :cheers:
