Author Topic: ArcadeSD PCB Problem  (Read 1663 times)
rsimp7255
  • Last login:February 10, 2023, 12:33:38 pm
« on: December 27, 2018, 07:41:44 pm »
Hi everyone,
 I just got everything up and running on my ArcadeSD PCB. The problem I'm having is the games will not load and play. I can scroll through the previews back and forth, but they will not load when selecting P1 or P2. I'm missing something but not sure what. Also, I went to test mode but can't move around to select anything. FYI...I went from a 60-1 to this. Thanks for any help.  ;)
To Alcohol! The cause of... and solution to... all of life's problems.
 - Homer J. Simpson
behrmr
  • Last login:April 23, 2021, 09:17:13 am
Re: ArcadeSD PCB Problem
« Reply #1 on: December 27, 2018, 08:59:23 pm »
Pins 25 and 26 on both solder and component sides of the harness can not be connected to anything. Make sure there are no pins in the harness there.
rsimp7255
« Reply #2 on: December 28, 2018, 08:51:51 pm »
Yep, that was it. Newb error. Thanks for the response.  :cheers:
 - Homer J. Simpson
behrmr
« Reply #3 on: December 29, 2018, 01:34:53 am »
Awesome! Glad it was an easy fix.
